It is currently Mon Aug 04, 2025 12:42 pm
 Post subject: dashpot damper
PostPosted: Fri Jun 13, 2008 8:06 am
I have a an hif carb and noticed while topping up the dashpot oil that the damper rod swivels around on the cap but is not loose. I read on one site new SU plastic capped dampers have a ball socket in the cap which allows the rod to be self aligning. Is that right?
Just curious. :roll:
PostPosted: Fri Jun 13, 2008 9:15 am
I'm not SU expert but I would say it's completely fine unless it has up and down movement.
PostPosted: Fri Jun 13, 2008 8:37 pm
just pulled my HIF44 oil damper rod out and it does swivel
PostPosted: Fri Jun 13, 2008 9:30 pm
thanks! :D
Guess thats why it has a bigger bulge on the cap rather than low profile flat one.?! To allow for some ball fitting type deal.
