gearbox or clutch or both
https://www.ausmini.com/forums/viewtopic.php?f=2&t=4304
Author:  sean [ Tue Jan 25, 2005 9:43 pm ]
Post subject:  gearbox or clutch or both
Took it for a test run today with brakes done and new suspension in they were all fine. New problem to solve is violent vibration in area between gear stick and gear box when I let the clutch out in any gear - the whole car judders and it seems loose in that area. is this the clutch or gearbox problems - what should I check ? - please help !
Author:  drmini in aust [ Wed Jan 26, 2005 6:40 am ]
I'd say either your engine mounts are gone, or you have a crap clutch. See your other post. :wink:
Author:  Gezo [ Wed Jan 26, 2005 7:55 am ]
Hi,
Had a similar problem,spent a fortune replacing everything in the front end. Ended up being only one bolt connected to the remote housing instead of two. So everytime you,d take off or put a bit of accelleration on there would be knocking/shudder/vibration of the remote housing hitting the body.Worth a quick look.
