unidentified switch thing https://www.ausmini.com/forums/viewtopic.php?f=2&t=4310 |
Author: | sean [ Wed Jan 26, 2005 1:42 am ] |
Post subject: | unidentified switch thing |
Anyone know what the switch might be on the right side of my steering wheel. it is mounted under the dash and you can turn it right and lft and has the letter p on it ? |
Author: | min13k [ Wed Jan 26, 2005 2:03 am ] |
that is the dimmer switch for the dash lights makka |
Author: | supercharged 850 [ Wed Jan 26, 2005 2:45 am ] |
Ah..... that would make the "P" a "d" ![]() No wonder I couldnt think of the answer... |
Author: | Namibian CAMEL [ Wed Jan 26, 2005 2:58 am ] |
How come i dont have a little switch?? ![]() ![]() |
Author: | mini_me [ Wed Jan 26, 2005 4:16 am ] |
Post subject: | dimmer switch |
As Makka said its a dimmer s/w which is used to dim the dash lights.The P stands for "park".My MGB has the same s/w. ![]() |
Author: | sean [ Wed Jan 26, 2005 3:46 pm ] |
Ta will see if it works now |
Author: | drmini in aust [ Wed Jan 26, 2005 4:04 pm ] |
It allows you to adjust between dim, and dimmer... ![]() ![]() ![]() |
Author: | 1380 yellow devil [ Wed Jan 26, 2005 6:21 pm ] |
drmini in aust wrote: It allows you to adjust between dim, and dimmer...
![]() ![]() ![]() No Mine I fixed them By putting on a relay and running a heavy earth wire to each light straight from the battery. Very Bright NOW ![]() ![]() |
