It is currently Sun Jul 27, 2025 8:43 am
PostPosted: Thu Jun 19, 2008 2:17 pm
Hi i was just wondering what the thread size is for the water sender in a late clubman head. I need a adapter for my speco temp gauge and i was told to get 544-42 5/8"unf x 18mm-1.5 but it was way to big. I emailed speco and these are the available adapters:
544-41 5/8"unf x 16mm-1.5
544-43 5/8"unf x 1/2"npt
544-44 5/8"unf x 3/8"npt
544-45 5/8"unf x 5/8"unf
Which one will i need?
Also the sender doesnt go all the way in the hole? Will i be able to still use it? Has anyone used this gauge on a late clubman?
PostPosted: Thu Jun 19, 2008 6:08 pm
The Omnipotent and all knowing Drmini in aust wrote:
The temp sender in head is either 5/8-16 (UNS bastard thread) or 5/8-18 UNF (depending who you talk to).
All I can say is, a 5/8-18 UNF tap cleans it out properly without removing metal so IMO it's close enough. AND, you can buy them... Wink
From a while back...
PostPosted: Thu Jun 19, 2008 6:21 pm
I tried 5/8"unf x 18mm-1.5, and it was to big.
PostPosted: Thu Jun 19, 2008 6:29 pm
When you say too big - would it screw in or jamb up - the Doc said to run a tap through first
David L
PostPosted: Thu Jun 19, 2008 6:37 pm
I cant even screw it in, it doesn't fit in the hole at all.
Users browsing this forum: No registered users and 112 guests
