It is currently Sat Jul 26, 2025 10:08 pm
 Post subject: The importance of Smoke
PostPosted: Thu Jun 19, 2008 4:27 pm
Some of you may have read this information previously but if not here it is. :lol:
This info is obviously important to the mini due to its wide use of Lucas products.
A Treatise on the Importance of Smoke
by Joseph Lucas
Positive ground depends on proper circuit functioning, which is the transmission of negative ions by retention of the visible spectral manifestation known as "smoke". Smoke is the thing that makes electrical circuits work. We know this to be true because every time one lets the smoke out of an electrical circuit, it stops working. This can be verified repeatedly through empirical testing. For example, if one places a copper bar across the terminals of a battery, prodigious quantities of smoke are liberated and the battery shortly ceases to function. In addition, if one observes smoke escaping from an electrical component such as a Lucas voltage regulator, it will also be observed that the component no longer functions. The logic is elementary and inescapable!
The function of the wiring harness is to conduct the smoke from one device to another. When the wiring springs a leak and lets all the smoke out of the system, nothing works afterward.
Starter motors were considered unsuitable for British motorcycles for some time largely because they consumed large quantities of smoke, requiring very unsightly large wires.
It has been reported that Lucas electrical components are possibly more prone to electrical leakage than their Bosch, Japanese or American counterparts. Experts point out that this is because Lucas is British, and all things British leak. British engines leak oil, British shock absorbers, hydraulic forks and disk brake systems leak fluid, British tires leak air and British Intelligence leaks national defense secrets. Therefore, it follows that British electrical systems must leak smoke.
Once again, the logic is clear and inescapable.
In conclusion, the basic concept of transmission of electrical energy in the form of smoke provides a logical explanation of the mysteries of electrical components - especially British units manufactured by Joseph Lucas, Ltd.
"A gentleman does not motor about after dark." Joseph Lucas (1842 - 1903)
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu Jun 19, 2008 4:49 pm
*remembers the RARE LOOK jar of genuine Lucas smoke on ebay a few years ago*
PostPosted: Thu Jun 19, 2008 4:51 pm
especially on the tube earlier this week!!!
nice little theory :D
78 Leyland Mini - Prince
PostPosted: Thu Jun 19, 2008 5:54 pm
Give Ash some flowers Nick .
Poeee, I do believe this is the stuff you are thinking of!
http://www3.telus.net/bc_triumph_registry/smoke.htm
PostPosted: Thu Jun 19, 2008 7:15 pm
That would be it.
Teehehehe. :lol:
PostPosted: Thu Jun 19, 2008 7:35 pm
Lucas - Prince of Darkness.....
My favourite -
Lucas - Inventor of the Intermittent windscreen wiper
http://www.mez.co.uk/lucas.html
and this one is good too... but perhaps should live in the BFH thread...
http://www.mez.co.uk/haynes.html
