wiring question https://www.ausmini.com/forums/viewtopic.php?f=2&t=43143 |
Author: | mini-dunger [ Thu Jun 19, 2008 10:27 pm ] |
Post subject: | wiring question |
Hi all I was just wondering if the depress function on the indicator stalk operates the washer squirter deally or the horn? I have test rigged the wiring and now a light comes on on the dash board when I depress said stalk.. oh lastly, what terminal on the alternator remains vacant? cheers guys |
Author: | doogie [ Thu Jun 19, 2008 10:29 pm ] |
If its one a clubman the end of the blinker stalk is for the horn, the washer switch is down n the centre swich panel. Doogie |
Author: | mini-dunger [ Thu Jun 19, 2008 10:32 pm ] |
thanks mate |
Author: | mini-dunger [ Sat Jun 21, 2008 6:15 pm ] |
another questions I have a rouge brown wire with a blue trace, its constantly live if that helps. also should my oil pressure sender and my temp guage be live aswell? thanks guys |
Author: | Mick [ Sat Jun 21, 2008 7:19 pm ] |
I can't remember what the brown/blue wire is supposed to do without my manual, but yes there will be a voltage at the oil switch and the temp sender . The oil switch acts as a switch to ground on the ground side of the oil light, the sender acts as a variable temperature dependant resistor for the gauge(but it's only 10 volts here). |
