It is currently Sat Jul 19, 2025 8:18 am
 Post subject: Speedo cable
PostPosted: Wed Jan 26, 2005 4:52 pm
l know there are two types of speedo cables screw on for early model minis and push on for late models. Is this the internal cable end that fits into the gearbox housing the same for both screw on and push on ? That is should both cables have a square end ?
My present system uses a screw on cable with a square end. I am redoing the instrument cluster and dash using gauages of a triumph dolomite which uses the push on cable. l purchased a new push on cable which has an oval gearbox end and tested it by attaching it to the gearbox housing and running the engine in gear however the cable does not turn. Do you think l have got the wrong cable or maybe the gear housing for screw on and push on cable are different?
PostPosted: Wed Jan 26, 2005 5:52 pm
It should be square on the gearbox end. Mine was taken out before I got it and had to sides flattened to make the square smaller and then a smaller cable would fit and work fine.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Wed Jan 26, 2005 6:16 pm
Push the cable in from the top!!!!
Yes the bottom end is the same square end used on 99.99999999% of Pommy cars. :wink:
PostPosted: Wed Jan 26, 2005 7:46 pm
Took some photos of the gearbox end of the cable.Does not look square to me.
Do you think this is the correct cable? The speedo end connects and works fine.
See photos at http://photobucket.com/albums/v515/chasg/
cheers chasg
PostPosted: Wed Jan 26, 2005 9:46 pm
Nope it don't look right to me... should be square ended, like the top is. :wink:
