It is currently Fri Jul 18, 2025 4:35 pm
 Post subject: Generators
PostPosted: Sat Jun 21, 2008 6:47 pm
Hey all I have a English import 850 it has a generator I was wondering how hard it is to change it over to a alternator???? It is not a negative earth either
PostPosted: Sat Jun 21, 2008 7:31 pm
Don't, if it is an english import 850, leave it alone. If the generator is stuffed buy a brand new one for less than $100 from mg heritage or karcraft in sydney.
There is nothing wrong with generators, i use them in my countryman and have never had an issue.
PostPosted: Mon Jun 23, 2008 9:45 am
Second that suggestion.
Retain the generator.
I guess its an early car.
PostPosted: Mon Jun 23, 2008 10:33 am
Conversion to negative earth is easy, and unless you need a lot of amps a generator is perfectly adequate.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Mon Jun 23, 2008 11:42 am
Conversion to neg ground is easy- you would need to do it for a modern radio/stereo, but by all means keep the generator, they work fine unless you have a zillion lights and amps and subs... :wink:
