Generators https://www.ausmini.com/forums/viewtopic.php?f=2&t=43195 |
Author: | i got a mini [ Sat Jun 21, 2008 6:47 pm ] |
Post subject: | Generators |
Hey all I have a English import 850 it has a generator I was wondering how hard it is to change it over to a alternator???? It is not a negative earth either |
Author: | aaron [ Sat Jun 21, 2008 7:31 pm ] |
Don't, if it is an english import 850, leave it alone. If the generator is stuffed buy a brand new one for less than $100 from mg heritage or karcraft in sydney. There is nothing wrong with generators, i use them in my countryman and have never had an issue. |
Author: | Mort Subite [ Mon Jun 23, 2008 9:45 am ] |
Second that suggestion. Retain the generator. I guess its an early car. |
Author: | Timbo [ Mon Jun 23, 2008 10:33 am ] |
Conversion to negative earth is easy, and unless you need a lot of amps a generator is perfectly adequate. Tim |
Author: | drmini in aust [ Mon Jun 23, 2008 11:42 am ] |
Timbo wrote: Conversion to negative earth is easy, and unless you need a lot of amps a generator is perfectly adequate.
Tim Conversion to neg ground is easy- you would need to do it for a modern radio/stereo, but by all means keep the generator, they work fine unless you have a zillion lights and amps and subs... ![]() |
