It is currently Sat Jul 19, 2025 1:41 am
 Post subject: fuel gauge goes down
PostPosted: Sat Jun 21, 2008 7:09 pm
Hello i'm having a weird problem with my fuel gauge.
It seems that when i turn the car on the fuel gauge move's along to what i think is about right but when i'm driving it starts going down, then when i stop at say some traffic lights it starts to rise again?
I have a spare voltage reg that i've tried swapping over and get the same result.
Its a round nose center speedo type.
Anyone have any ideas?
Thanks for the help :)
PostPosted: Sat Jun 21, 2008 7:33 pm
Alternator has issue i would say. You are getting voltage drop when you drive.
PostPosted: Sat Jun 21, 2008 7:41 pm
Good call i didn't think of that. I'll check that out. Thank you.
PostPosted: Sat Jun 21, 2008 9:36 pm
I would be interested in your findings as I have a 73 mini van which has the same problem.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Jun 21, 2008 9:39 pm
This space for rent
Mine's doing the same thing at the moment -- fuel gauge goes up, fuel gauge goes down.
I'm replacing the alternator next week, as mine is on the way out.. I'll let you know if the problem goes away.
PostPosted: Sat Jun 21, 2008 10:08 pm
My fuel gauge goes down as I drive as well, however it doesn't go back up until I fill it.
:D
PostPosted: Sat Jun 21, 2008 10:38 pm
Mine did that for years. The faster I went the lower it read. Then you stop, and watch it come up.... :evil:
But I could put it up on stands in the garage and run it at 50 or 60mph and it never went down. Had me stumped, until...
I decided to try a new 10V electronic voltage stabilizer, as I had one of Wombat's here.
IT FIXED IT. :D
It seems the problem was that the old ones are a vibrator similar to a blinker can- road vibration under way reduces the output voltage when they get old. So the gauge reads lower with speed.
So I flung the old one far, far away. 8)
PM Wombat for a new one, I bet it fixes it.
PostPosted: Sat Jun 21, 2008 11:33 pm
i keep hearing about wombat's fancy voltage stabilizers, i think i'll give it a try i'm a bit curious.
PM'd wombat, i'll post the results.
thanks for the help.
