well I am starting to see the light at the end of the tunnel on my clubman van rebuild.
I have finished the bare metal strip down and have dropped the shell, doors and bonnet off at the panel beaters to get the holey bits welded up and the fan sprayed.
I am now looking through my boxes of bits and working out what to replace
My suspension questions are:
1. My rear suspension cone and metal strut are not joined together. Are they meant to be joined by a bolt? I think so but just checking.
2. The alloy strut seems to have been chopped at one point and to get it up to a semi legal height washers are between this and the knuckle. This seems dodgy on a high scale. Should I just replace the struts? If so adjustable would be a wise move?
My other question is what to replace on the car while it is apart.
I am planning on replacing the brake lines ( metal and rubber), fuel lines and all the grommets I can get my hands on. I have seen a brakeline kit on the internet but it seems a bit excessive at 250. Has anyone got a brake shop to do this for them? If so how much? It should be easy enough to get the pipes and attachments and make my own. My mum has the flarer and pipe cutter ( don't ask
David
