It is currently Wed Jul 16, 2025 10:50 am
 Post subject: More engine number help
PostPosted: Sun Jun 22, 2008 12:39 pm
My Leyland Mini S came with an engine that has been replaced at some time.
It's number is 10YTAH4659 2
Any clues to it's origin.
PostPosted: Sun Jun 22, 2008 1:49 pm
yep most likely out of a mini
PostPosted: Sun Jun 22, 2008 3:34 pm
Morris 1100 is my bet.
PostPosted: Sun Jun 22, 2008 5:22 pm
Yes it is a Morris 1100 motor.
A Mini K would be 10YC/Ta/H
Mini Clubman/ Leyland Mini /Mini S would be 1000 to 1016
PostPosted: Sun Jun 22, 2008 7:46 pm
Thanks Morris 1100
I knew you would know.
Is there any difference in spec's between the original Leyland 'S' motor and the 1100?
PostPosted: Sun Jun 22, 2008 9:24 pm
Most of the differences would be in the gearbox, so hopefully they kept the Mini box. The Morris 1100 had 3 syncro and rubber unis, the Leyland Minis had 4 syncro and later ones had rod-change and pot joints.
The late 1100s fitted to later K, Clubman and Leyland Minis had head bolts instead of studs and nuts. This is a step backwards (and probably only done to increase local content)
PostPosted: Sun Jun 22, 2008 9:50 pm
Thanks for that.
I'll have do do some further investigation.
This is my first Mini, so i'm still finding my way.
Users browsing this forum: Hobson and 86 guests
