It is currently Sat Jul 19, 2025 10:32 am
 Post subject: car wont idle
PostPosted: Mon Jun 23, 2008 7:21 pm
ok i try to start my car and it wont idle i turn it over turns over for a while then finally it fires and then stalls and do it again and same result again and same result and i dont know what it is...any idea
PostPosted: Mon Jun 23, 2008 7:22 pm
High heel ninja
Maybe you could adjust your idle a bit higher.
Doogie
PostPosted: Mon Jun 23, 2008 7:23 pm
no dad tries but still nothing.........
PostPosted: Mon Jun 23, 2008 7:51 pm
could be a million things... do you have a workshop manual?
PostPosted: Mon Jun 23, 2008 9:17 pm
What have you got? Carby, engine size etc.
Try the process of elimination, is it getting fuel? a quick way to check is undo the fuel line to the carb, and hold the end into a container, have someone
turn the ignition over quickly and see if the fuel pump is pumping and not stopping, do you know if you have a mechanical or electric/electronic pump?
If its ok, then check for a good spark
PostPosted: Mon Jun 23, 2008 9:20 pm
ausmini mod
ausmini mod
Take out your spark plugs and see if they are wet and black, could have flooded the motor too
Tell us more about the motor as people have said and also what changed?
Is it a points distributor? Did you change the points or condensor? What happens if you try to start with no choke and NO accellerator pedal?
How long do you have to crank it over to actually start it?
Peter.
PostPosted: Tue Jun 24, 2008 9:21 pm
its an 1100 cc inch anda half carb extractors disriutor with oints......... its getting fuel
PostPosted: Tue Jun 24, 2008 9:31 pm
Check your points gap, (I think its 15 thou from memory) and clean them up if needed with a small file or some wet n dry. Check for a decent spark next then
PostPosted: Tue Jun 24, 2008 10:04 pm
ausmini mod
ausmini mod
ok, so did you have a chance to try any of the ideas??
Are the plugs wet or black?
Did you change points or condensor?
How long do you have to crank it before it actually kicks?
Anything else change?
Peter
