It is currently Mon Aug 04, 2025 5:12 am
 Post subject: Alternator kits
PostPosted: Fri Jun 27, 2008 10:41 am
Milatsmadmini
Gday guys,
My alternator isnt really holding much of its "go" so is there anywhere to get a re-furb kit or bush kit?
Matt
PostPosted: Fri Jun 27, 2008 10:56 am
I bought one off eBay UK
http://cgi.ebay.com.au/Heavy-Duty-Lucas-15-16-17-18-ACR-Alternator-Repair-Kit_W0QQitemZ160252689021QQihZ006QQcategoryZ9903QQrdZ1QQssPageNameZWD2VQQcmdZViewItemQQ_trksidZp1638Q2em122
the bits are available here if you have an autoelectrical wholesaler handy but for me this was more conveinient
David L
PostPosted: Fri Jun 27, 2008 11:03 am
Bearing places eg CBC will sell you the bearings, and any autoelectrician should have brushes. The latter are easily fitted without disassembly on most Lucas, except the 15AC without the plastic end cover (early Clubby)- they need to be stripped to fit
Not much else goes wrong, unless the voltage regulator carks it..
PostPosted: Fri Jun 27, 2008 5:25 pm
Ingrams used to supply diode packs, but looks like its now a real hassle.
http://www.ashdown-ingram.com.au/CA2571B7001714EB/page/eCatalogue?OpenDocument&1=05-eCatalogue~&2=~&3=~
