Can't blow my horn https://www.ausmini.com/forums/viewtopic.php?f=2&t=43526 |
Author: | Wombat [ Thu Jul 03, 2008 8:58 am ] |
Post subject: | Can't blow my horn |
I have 4 horns out of Minis/BMC cars. When I put a battery across the terminals I get nothing - except one makes a pop sound as though it's trying. Am I right in assuming they should work connected straight on a battery? |
Author: | Anto [ Thu Jul 03, 2008 9:00 am ] |
Yes they should. If they are original BMC horns I think (??) they usually have an adjuster screw of sorts - maybe adjust it and see if it makes a difference. |
Author: | Mike_Byron [ Thu Jul 03, 2008 9:06 am ] |
I agree with Anto, David Sometimes they just old and freeze. Try giving them a bit of a tap. Then try reversing the polarity. It shouldn't make any difference but sometimes it does. I don't know why. The horns in situ have positive power in all the time and blow when the negative goes to ground. Mike |
Author: | sports850 [ Thu Jul 03, 2008 9:46 am ] |
I've found a couple of sharp hits with a rubber mallet on the horn body to loosen things up can revive an old horn . I think a bit of corrosion can stick things together inside and earth the system . |
Author: | lilmatti_69 [ Thu Jul 03, 2008 1:20 pm ] |
Theres a screw on the back near the big one, loosen it until you cant hear the horn then screw it a quarter of a turn. |
Author: | Morris 1100 [ Thu Jul 03, 2008 5:09 pm ] |
Give it a tap. Turn the big screw in and out a bit to free it up. Fine tune with the little screw. They work fantastic after a tune. ![]() |
Author: | lil-ute [ Thu Jul 03, 2008 6:14 pm ] |
sorry wombat somebody has to say this VIAGRA |
Author: | Wombat [ Thu Jul 03, 2008 6:27 pm ] |
Definately don't need it but there are a few people here that need some Viagra Eye Drops - as they need to take a long hard look at themselves |
