Help with my rear van doors..
https://www.ausmini.com/forums/viewtopic.php?f=2&t=43530
Author:  Sydney_Leyland [ Thu Jul 03, 2008 12:17 pm ]
Post subject:  Help with my rear van doors..
So im in the process of hunting rust and fixing it found some nice bits in my rear van door and i cant for the life of me remove the glass!!..
Ive searched on here high and low and cant find the info for this... Please help..
Thankyou in advance :D
Andrew
Author:  Anto [ Thu Jul 03, 2008 12:42 pm ]
I believe the manual just says it pushes out from the inside?
Perhaps somebody can confirm.
Author:  justincase42 [ Thu Jul 03, 2008 12:45 pm ]
You just lift the seal and push from the inside. Theres a good change that the rubber seals will be rock hard if they are the otiginal ones. If it is the case, ur best option will be is to cut the seal with a stanley knife from the inside then push the glass and left over seal out. You will have to by new seals but when the seals are old and hard, they are pretty much impossible to get out and they fall apart.
Author:  awdmoke [ Thu Jul 03, 2008 12:50 pm ]
but you can't get new ones either :x
Author:  sports850 [ Thu Jul 03, 2008 1:15 pm ]
Nope , they are availible , not the cheapest rubber around (compared to a windscreen rubber) but still availible .
http://www.minisport.com.au/prod650.htm
(used minisport because their listing was easiest to find)
Author:  michaelb [ Thu Jul 03, 2008 2:01 pm ]
They push out with some leverage around the edge of the rubber with screw driver or similar. I have purchased new rubbers in the past 12 months but cant remember where from? Could have been minisport.
The rubbers around the door are also expensive, and do not fit as well as the old ones.
Author:  Sydney_Leyland [ Thu Jul 03, 2008 2:19 pm ]
Thanks everyone... i had to cut them off in the end and found a nice chunk of rust :?
Author:  yeehaa [ Thu Jul 03, 2008 4:27 pm ]
i purchased a set for my van late last year from mini bits and he charged my 75 for a set which i thought was a bargan so give them a call and they fit nice and easy :wink:
Author:  lil-ute [ Thu Jul 03, 2008 6:01 pm ]
when i had my mini front screen come and sit on my knee while driving down a highway when i went and had it fixed they said it is the same as one of the early commodores not sure which sorry
