Spi 1275 RPM/KPH
https://www.ausmini.com/forums/viewtopic.php?f=2&t=43571
Author:  blueminivan [ Fri Jul 04, 2008 7:20 pm ]
Post subject:  Spi 1275 RPM/KPH
Does anyone know the rpm in the appropriate gear for each of the speed limits?
I've got an SPi 1275 with an unconnected speedo cable.(hopefully).
Author:  Clubby74 [ Fri Jul 04, 2008 10:59 pm ]
Not directly but
Engine speed = Vehicle speed x Wheel rotations per km x diff ratio x gear ratio / 60
So I guess with a bit of google or maybe a search on here you will find your ratio's and a tape around your tyres will get you the last missing piece.
Author:  blueminivan [ Fri Jul 04, 2008 11:35 pm ]
Yeah OK thanks for the tip.....
But surely there's a few people out there that drive via the tacho that could give me a rough idea.
Author:  wyan [ Sat Jul 05, 2008 9:56 am ]
Mine was an Mpi but converted to carb now.. 70kms in forth is about 2500RPM and 100kms is about 3500-3600kms I think from memory.
My 1st gear is pretty short also.
Does this help?
Author:  Number86 [ Sat Jul 05, 2008 10:47 am ]
Diff ratio in my SPi is 3.44:1 (standard I believe), although I haven't driven it yet, this is the same ratio as my S. This makes 80km/h 3000rpm in fourth, 100km/h just under 4000. Hope this helps.
Author:  blueminivan [ Sat Jul 05, 2008 5:31 pm ]
Thanks for that.
I only needed a rough idea until I fix the problem.
