It is currently Wed Aug 06, 2025 10:26 pm
 Post subject: Might help someone
PostPosted: Sat Jul 05, 2008 5:13 pm
Replaceing the brakelines and finding it ackward measuring the old against the new pipe - was about to use the old string method when I noticed MiniSpares UK have the lengths of the sections in inches. I matched them up to a diagram of the brakelines and made up a table.
NOTE - number 5 - has different lengths depending where you look (Van/Moke is 104") and originally both Master Cylinder lengths were the same at 12" but they advise the brake is easier to fit at 13" (but wondering if using the larger Cooper S MC if you need longer again?)
M/M = male/male fittings each end - M/F = male/female
Anyway if it's useful use it - if not don't :roll:
PostPosted: Sat Jul 05, 2008 6:51 pm
Brilliant!
Someone please make this a sticky.
PostPosted: Sat Jul 05, 2008 9:08 pm
ha i just pulled that bolt-combination thing apart today. could have helped if i had seen this prior. Oh well apart now
PostPosted: Sat Jul 05, 2008 10:09 pm
Thank you Wombat
Truely useful
wild_willy
