It is currently Mon Jul 21, 2025 3:48 pm
PostPosted: Mon Jul 14, 2008 9:26 am
Initially, I thought my front left wheel bearings were stuffed, but we discovered the hub nut was a bit loose.
I bought a huge spanner which fits the nut, but it doesn't matter how hard I try I don't seem to be able to tighten the nut far enough to get it to the point where it is both tight enough AND it's in a position for me to put a split pin back through.
I had my brother sitting in the front seat with his foot on the brake pedal whilst I was belting the hell out of the spanner with B-est F-ing hammer I have. It won't budge any further in my hands.
Should I just back it off and put the split pin through or should I expect to be able to get it that little bit further?
PostPosted: Mon Jul 14, 2008 9:34 am
I sometimes back it off a little bit to get the split pin through - but that is after tightening it with a 1 metre long breaker bar with an extra 1 metre extender bar on it - so when I 'back it off' it is still bloody tight.
I think you actually need something with some extra leverage, unless that is a very long spanner you are using. Elsewise if you back it off it will likely end up loose again, which can potentially lead to damage.
PostPosted: Mon Jul 14, 2008 9:48 am
ummmmm 150lb/ft is the torque setting.....
PostPosted: Mon Jul 14, 2008 10:07 am
Well I for one don't have a torque wrench that goes that high, so I've always taken 150lb/ft as tightening it with my longest breaker bar until I'm damn near lifting the car up. Then it's tight. :wink:
PostPosted: Mon Jul 14, 2008 10:28 am
150ft/lb is someone (70kg) standing on the 1 foot long bar near the end
David L
PostPosted: Mon Jul 14, 2008 10:42 am
And if you really want to know - I think it is called the castellated nut. :wink:
KB
PostPosted: Mon Jul 14, 2008 2:32 pm
Thanks all for the replies! 8)
I was feeling pretty castellated myself when I couldn't turn that nut just a smidge more to make the pin go through.
A torque wrench might be my next splurge. :twisted:
PostPosted: Mon Jul 14, 2008 8:41 pm
drum brakes ??? or disc brakes???
PostPosted: Mon Jul 14, 2008 10:26 pm
If the hub nut has worked loose, there could be a problem, like the hub flange is worn or the spacer itself needs to be machined to compensate for any bearing wear. Best if you check it out fully :wink:
PostPosted: Mon Jul 14, 2008 10:32 pm
dont forget you dont just have one hole to put a split pin in
PostPosted: Mon Jul 14, 2008 10:34 pm
Yes you often do, if it's a late disc brake CV. :wink:
PostPosted: Mon Jul 14, 2008 11:00 pm
Thanks for the advice, guys. 8)
Sounds like I better get it checked out.
PostPosted: Wed Jul 16, 2008 7:20 am
Will only help if your torque wrench goes to 150ft/lb - not many do - and anyway no idea how you appy enough torque to a torque wrench to 150ft/lb w/o an extension. You are better off investing in a 34mm socket (better than a spanner anyway) and a long breaker bar, plus a lenght of pipe and stand on it.
(though a torque wrench is very useful in general).
PostPosted: Wed Jul 16, 2008 8:00 am
If your not in a hurry wait till Supercrap have a store wide 20% off sale (usually Public Holiday weekends ) I got mine then and it's one in a hard plastic case for safe storage.
David L
PostPosted: Wed Jul 16, 2008 11:27 am
True. I should've bought a socket instead of the spanner. I didn't even think of it. Bloody thing cost me $80 and there's no way to get any leverage. Who knows when I will need a 34mm spanner again. As it was I was half wondering if I wouldn't take out the flare with my BFH swings.
Lucky I didn't! :roll:
Users browsing this forum: 68+86auto and 81 guests
