It is currently Tue Jul 22, 2025 1:55 pm
 Post subject: 10inch to 12inch?
PostPosted: Thu Mar 19, 2009 3:27 pm
hey great forum.
i am wanting to know if it is a straight swap from 10inch to 12inch rims? What affects will it have on handling, suspension. Is there any thing else i should consider?
thanks.
PostPosted: Thu Mar 19, 2009 3:39 pm
In most instances you don't have to do anything going from 10" to 12". Worst case you need to put spacer drums on (depending on the offset of the wheels), and/or flares.
Handling with simular tyres is very comparable between 10" and 12", but the range of tyres is greater in 10".
