Cylinder head AEG163 - OK, what is it?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=4393
Author:  been to Hay [ Sat Jan 29, 2005 7:39 pm ]
Post subject:  Cylinder head AEG163 - OK, what is it?
Found this under some shelving in the garage. AEG163. Also has a 2 cast into the thermostat body (underside). Anybody know what is for? Many thanks.
Author:  mooman10_0 [ Sat Jan 29, 2005 7:46 pm ]
Post subject:  m
Im interested in the answer to this aswell as I also have one on the shelf in the shed
Author:  doogie [ Sat Jan 29, 2005 8:48 pm ]
MK1 Cooper S head, may say they are the best heads for a big bore engine, what are you going to do with it?
Doogie
Author:  been to Hay [ Sat Jan 29, 2005 9:43 pm ]
mk1 s - OK, that makes some sense. It has also been ported and has had 2 dowell pins fitted for (i assume) locating the manifold as the recesses for the locating rings in the inlet ports has been ground away.
I will clean it up and get it crack tested I reckon.
Thanks for the reply
Author:  bnicho [ Sat Jan 29, 2005 9:47 pm ]
I've been to Hay too! :lol:
Author:  doogie [ Sat Jan 29, 2005 9:50 pm ]
I've been 11 times, 12 after this June.
Doogie
Author:  bnicho [ Sat Jan 29, 2005 9:59 pm ]
1999 - Wheel bearing went on the Hay Plain on the way home!
2000 - Engine blew a week before Hay, so I stayed home.
2001- Welsh plug fell out of my new motor. Found a Morris 1100 in a paddock and fitted a second-hand welsh plug from that. It worked fine!
2002 - Didn't go - had to work.
2003 - Trailered the Mini behind my 4x4. No problems.
2004 - Didn't go - had to work.
2005 - I will be there!!
Author:  min13k [ Sat Jan 29, 2005 11:34 pm ]
i went 2003
got sick as a dog frowing up and had diarear something cronic was shitting through the eye of a needle
but other than that it was great
makka
Author:  been to Hay [ Sun Jan 30, 2005 12:04 am ]
.h
Author:  min13k [ Sun Jan 30, 2005 12:09 am ]
my mini was in the final gambia green mini (turquose) female driveing i was in hotel room by this time ........
and no it was not self inflicted had a bug
hopeing to have one of my cars on the road by then
makka
Author:  mooman10_0 [ Sun Jan 30, 2005 8:03 am ]
Post subject:  m
Just wondering what is different about these heads "AEG 163", cause when I remember looking at the one i have inthe shede, I cant remember it being much different to a normal one?
Author:  doogie [ Sun Jan 30, 2005 9:42 am ]
11 stud for a start, big valves, scollops around the inlet & exhaust ports, give it to me if it in the way of you :D
Doogie
