It is currently Sun Jul 27, 2025 1:36 am
PostPosted: Thu Jul 17, 2008 1:35 pm
good or bad idea?
have both, other wise i will swap the diff housing over for the gearboxes.
whats involved in doing this?
1962 850,Frog
PostPosted: Thu Jul 17, 2008 4:03 pm
i cant offer any advice but,
baby matt (mattvan74) has a bigblock on an 850 box in queenie.
PostPosted: Thu Jul 17, 2008 4:08 pm
I thought that was a 4 synchro 1100S box with an 850 diff housing attached?
PostPosted: Thu Jul 17, 2008 4:36 pm
ahh yea could be, best to ask him.
PostPosted: Thu Jul 17, 2008 4:41 pm
If the box is rebuild correctly it should handle the power you just won't have the syncros :? I reckon you use a late box with the 850 diff.
PostPosted: Thu Jul 17, 2008 4:54 pm
Better option to retain a magic wand with 1275 is a Mini K/Clubman Van box. They are your Mini K/'Mk2 Cooper S' box with a magic wand diff housing. You can obviously also run Mk2 Cooper S gears.
PostPosted: Thu Jul 17, 2008 5:21 pm
Are they also like the Moke? Not really Magic Wand but a short rod change with the gear stick closer to the firewall :?
David L
PostPosted: Thu Jul 17, 2008 5:44 pm
I believe some early 850 boxes had bushes under the gears instead of roller bearings. You would want to be sure what's in it before you put a 1310 on it.
Don't see why the magic wand mechanism wouldn't work on a remote box though.
Pete
PostPosted: Thu Jul 17, 2008 5:52 pm
Just use the magic wand remote... :wink:
PostPosted: Thu Jul 17, 2008 7:06 pm
Its a 3 Synchro Box with an 850 diff housing.
The pudding stirrer is best gearshift in my opinion. I love it, its quicker than most once you get use to it.
Matt
PostPosted: Thu Jul 17, 2008 7:10 pm
Avoid the early 850 gearbox housing- to swing the 1275 rods you would need to cut 4 BIG HOLES in the front and weld or Araldite them over, amongst other mods.. :shock:
I did one years ago because it was all I had, I put 998 Cooper gears in it (needle rollers in the gears) too because I acquired a set... :lol:
PostPosted: Thu Jul 17, 2008 8:19 pm
Matt
so i'm best to go with the box that the 1310 was already on and change the diff housing so i can retain the magic wand yeah?
. . . and maybe some straight cut gears :lol:
1962 850,Frog
PostPosted: Thu Jul 17, 2008 8:22 pm
I would use a Mini-K/Mk2S/1098 Clubby 4 synchro box, and put an 850 diff housing on it as Wombat did.
Note when it's bolted up, the bearing bores need checking for size & roundness.
The Morris 1100S box was 3 synchro, not 4.
PostPosted: Thu Jul 17, 2008 8:57 pm
The magic wand remote type as fitted to Mokes and pictured above is what I have stashed away to use on my Traveller. I refuse to cut a hole in the floor.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
