It is currently Sun Jul 27, 2025 1:34 am
PostPosted: Thu Jul 17, 2008 7:33 am
I'm thinking it can't be done for A/A+ reasons, but a 2nd hand refurbishing one sounds easier than fixing my tired box with buggered synchros.
TIA :)
PostPosted: Thu Jul 17, 2008 7:21 pm
Sure, it will work.
You need to run the right primary gear for whatever idler you are using (A or A+), and the box `might' need a little grinding in a couple of spots to clear the rods, but that's it.
No big deal.
However being a 3 synchro (I assume `tis) it's not as strong as any 4 synchro one, and the ratios are crappier too.
