It is currently Sat Jul 19, 2025 7:30 am
 Post subject: steering rack rmeoval?
PostPosted: Sun Jan 30, 2005 10:32 am
Has anyone got any tips for loosening the clamp bolt right at the bottom of the steering column on the end near the floor? I have taken off the nut, but the bolt and the clamp still wont loosen, and i can't pull it out!!
PostPosted: Sun Jan 30, 2005 10:39 am
If you can get a screwdriver to level the steering rack away from the body you might be able to do it. I think thats what I had to do to get mine out.
PostPosted: Sun Jan 30, 2005 1:14 pm
You are fiddling in a dangerous area....if you don't get it spot on you can end up having a Mini with no steering.....do a search on steering column (its the pinch bolt) etc on Ausmini as this has been covered before. Whatever you do don't depart from the instructions in the manual.
PostPosted: Sun Jan 30, 2005 1:18 pm
Tap upwards on the under side of the steering wheel boss. A nice block of wood helps to protect it against damage from blows of the BFH.
Edit - that bolt has to be out first :oops:
