It is currently Sat Jul 19, 2025 10:31 am
PostPosted: Sat Jan 29, 2005 7:39 pm
Found this under some shelving in the garage. AEG163. Also has a 2 cast into the thermostat body (underside). Anybody know what is for? Many thanks.
 Post subject: m
PostPosted: Sat Jan 29, 2005 7:46 pm
Im interested in the answer to this aswell as I also have one on the shelf in the shed
PostPosted: Sat Jan 29, 2005 8:48 pm
High heel ninja
MK1 Cooper S head, may say they are the best heads for a big bore engine, what are you going to do with it?
Doogie
PostPosted: Sat Jan 29, 2005 9:43 pm
mk1 s - OK, that makes some sense. It has also been ported and has had 2 dowell pins fitted for (i assume) locating the manifold as the recesses for the locating rings in the inlet ports has been ground away.
I will clean it up and get it crack tested I reckon.
Thanks for the reply
PostPosted: Sat Jan 29, 2005 9:47 pm
I've been to Hay too! :lol:
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sat Jan 29, 2005 9:50 pm
High heel ninja
I've been 11 times, 12 after this June.
Doogie
PostPosted: Sat Jan 29, 2005 9:59 pm
1999 - Wheel bearing went on the Hay Plain on the way home!
2000 - Engine blew a week before Hay, so I stayed home.
2001- Welsh plug fell out of my new motor. Found a Morris 1100 in a paddock and fitted a second-hand welsh plug from that. It worked fine!
2002 - Didn't go - had to work.
2003 - Trailered the Mini behind my 4x4. No problems.
2004 - Didn't go - had to work.
2005 - I will be there!!
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Sat Jan 29, 2005 11:34 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i went 2003
got sick as a dog frowing up and had diarear something cronic was shitting through the eye of a needle
but other than that it was great
makka
PostPosted: Sun Jan 30, 2005 12:04 am
.h
PostPosted: Sun Jan 30, 2005 12:09 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
my mini was in the final gambia green mini (turquose) female driveing i was in hotel room by this time ........
and no it was not self inflicted had a bug
hopeing to have one of my cars on the road by then
makka
 Post subject: m
PostPosted: Sun Jan 30, 2005 8:03 am
Just wondering what is different about these heads "AEG 163", cause when I remember looking at the one i have inthe shede, I cant remember it being much different to a normal one?
PostPosted: Sun Jan 30, 2005 9:42 am
High heel ninja
11 stud for a start, big valves, scollops around the inlet & exhaust ports, give it to me if it in the way of you :D
Doogie
