steering rack rmeoval? https://www.ausmini.com/forums/viewtopic.php?f=2&t=4401 |
Author: | monrel [ Sun Jan 30, 2005 10:32 am ] |
Post subject: | steering rack rmeoval? |
Has anyone got any tips for loosening the clamp bolt right at the bottom of the steering column on the end near the floor? I have taken off the nut, but the bolt and the clamp still wont loosen, and i can't pull it out!! |
Author: | rampage101 [ Sun Jan 30, 2005 10:39 am ] |
If you can get a screwdriver to level the steering rack away from the body you might be able to do it. I think thats what I had to do to get mine out. |
Author: | 9YaTaH [ Sun Jan 30, 2005 1:14 pm ] |
Post subject: | Re: steering rack rmeoval? |
monrel wrote: Has anyone got any tips for loosening the clamp bolt right at the bottom of the steering column on the end near the floor? I have taken off the nut, but the bolt and the clamp still wont loosen, and i can't pull it out!!
You are fiddling in a dangerous area....if you don't get it spot on you can end up having a Mini with no steering.....do a search on steering column (its the pinch bolt) etc on Ausmini as this has been covered before. Whatever you do don't depart from the instructions in the manual. |
Author: | WhoDat [ Sun Jan 30, 2005 1:18 pm ] |
Tap upwards on the under side of the steering wheel boss. A nice block of wood helps to protect it against damage from blows of the BFH. Edit - that bolt has to be out first ![]() |
