It is currently Sat Jul 19, 2025 8:16 am
PostPosted: Fri Jan 28, 2005 1:10 pm
Hi
I am thinking of buying a roundose rolling shell and changing everything from my 1275 mini Clubman (Not 1275GT or 1275LS) over to it.
This is after I take the roundnose back to bare metal and paint it or get it painted) :D
OK that might be down the track a bit :lol:
The thing is I don't want to be forever buying roundnose parts as the clubman ones won't fit :?
So what doesn't make the swap? Obviously bonnet, grill, front subframe?
What about bumpers? doors?
The parts don't need to be 850 looking as I can do that later (and I like the clubman interior)
Or should i really be asking what does make the swap :roll:
Thanks, Arrin
Roads need more corners
PostPosted: Fri Jan 28, 2005 1:12 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
door's wont fit bumpers will but are diferent
basicly every thing else will fit but what you stated as the obviuose
makka
PostPosted: Fri Jan 28, 2005 1:15 pm
Subframes will fit. Aslong as you stick with dry and not hydrolastic.
Doors wont fit, the catch panel is completely different.
Other than that, everything else will fit.
PostPosted: Fri Jan 28, 2005 1:33 pm
So the front subframe will go from a clubman into a roundnose? I thought it might be longer as the engine bay is...
Why does the Hydrolastics make a difference? my clubman has hydrolastics and I would like to try and keep the wet suspension if I can.
How much is a decent price for a rolling shell with doors and subframe :?:
PostPosted: Fri Jan 28, 2005 2:07 pm
You can go wet easy, just replace both front and rear subframes and all the right piping.
PostPosted: Fri Jan 28, 2005 4:08 pm
I'd keep it wet- to improve the ride and handling fit front shocks with brackets, and comp rear hydro bumpstops. :wink:
PostPosted: Fri Jan 28, 2005 4:31 pm
Thanks guys, Yer I was trying to keep the hydro cause I thought it was a really neat sort of idea and a bit of motoring history.
I am reconditioning the rear swing arms so I will get some new bump stops at the same time.
What do the Comp bump stops look like? I'm sure I will get sold the wrong ones :lol:
Any ideas on what a good straight shell with a little bit of rust is worth ?
(I know how long is a piece of string) :wink: A rough figure would be good though
PostPosted: Fri Jan 28, 2005 4:39 pm
Downside on Hydro is that it will need pumping up every non and then.
But if you leave it low it looks bloody good.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Fri Jan 28, 2005 4:40 pm
$600 would get ya something decent, I would say. Thats if it's missing EVERYTHING else.
PostPosted: Fri Jan 28, 2005 4:50 pm
Rear bumpstop kit here-
http://www.minimania.com/web/SUBTYPE/Se ... entory.cfm
Available from www.karcraft.com.au for $72 approx per set.
Forget the comp front kit- they are too bloody high, except for rallying.. :lol:
PostPosted: Fri Jan 28, 2005 6:43 pm
Hi Arrin,
have you found Fyshwick yet?? Check out these guys for parts:
http://classicmotoring.site.net.au/
PostPosted: Fri Jan 28, 2005 8:13 pm
Seats will fit. Rear cards will fit, but front door cards won't fit roundy doors.
PostPosted: Fri Jan 28, 2005 8:54 pm
rear cards are 2 piece on morris and 1 piece on leyland.
PostPosted: Fri Jan 28, 2005 10:58 pm
No reason why they wouldn't fit though???????????
PostPosted: Sat Jan 29, 2005 1:34 am
About twice half its length. No but seriously a shell about 300 to 600 bucks. But it really depends on your luck sometimes even a carton of beer.
Front disc brakes would rock on a roundie.
Fez
1965 850 Mini Van
1972 Clubman Van
Member of SDMC
