| ausmini https://www.ausmini.com/forums/ |
| Redrilling wheels https://www.ausmini.com/forums/viewtopic.php?f=2&t=44146 |
| Author: | spraycanmansam [ Wed Jul 23, 2008 4:58 pm ] |
| Post subject: | Redrilling wheels |
Does anyone know if it's possible to re drill steel wheels? I have a set of 13" steels that need to be 4" pcd ( 114.3mm at the moment ) and want to get them re drilled. Or if someone has 13" steels to fit a Morris Minor... |
| Author: | badassmini [ Wed Jul 23, 2008 5:21 pm ] |
| Post subject: | |
yeah you can get them re drilled i did this to my set of mags but you must get the old holes welded up. i got a engineer to do mine and then got a professional welder to weld up the old holes. |
| Author: | graham in aus [ Wed Jul 23, 2008 7:00 pm ] |
| Post subject: | |
Moke wheels....... |
| Author: | drmini in aust [ Wed Jul 23, 2008 7:12 pm ] |
| Post subject: | |
I put Austin A30s on a `77 Moke... they were 13x3... No you can't redrill steels, they are press formed to suit their particular PCD when made. You can get many alloy wheels redrilled though, they are usually solid centre. |
| Author: | spraycanmansam [ Wed Jul 23, 2008 7:18 pm ] |
| Post subject: | |
drmini in aust wrote: I put Austin A30s on a `77 Moke... they were 13x3...
No you can't redrill steels, they are press formed to suit their particular PCD when made. You can get many alloy wheels redrilled though, they are usually solid centre. That's what I thought |
| Author: | Harley [ Wed Jul 23, 2008 7:21 pm ] |
| Post subject: | |
I have a set of 13" steel moke rims here, so they exist alright. |
| Author: | drmini in aust [ Wed Jul 23, 2008 7:23 pm ] |
| Post subject: | |
I would put a set of Superlight 13x6 or something on a Minor. My mate (Minor 1000 addict) runs Morris Major wheels on his now, they are 14". Better choice of tyres he says. |
| Author: | TheMiniMan [ Wed Jul 23, 2008 8:27 pm ] |
| Post subject: | |
13inch diam & 7inch wide steelo moke rims like these that i have sitting in my yard ready to sell to anyone who wants them??? yeah ???-->
| Author: | spraycanmansam [ Wed Jul 23, 2008 8:34 pm ] |
| Post subject: | |
Geez I would've loved those! The offset's too huge though Anyone else!? I think I'll place a wanted ad. Mini's are the same pcd right? ( 4 inch ) |
| Author: | 1018cc [ Wed Jul 23, 2008 8:41 pm ] |
| Post subject: | |
Yep, mini's are a 4x4" PCD |
| Author: | simon k [ Wed Jul 23, 2008 10:36 pm ] |
| Post subject: | |
depends which minor... MM's are different to Series 2 / 1000's cortina wheels will go on an MM |
| Author: | spraycanmansam [ Wed Jul 23, 2008 10:47 pm ] |
| Post subject: | |
simon k wrote: depends which minor... MM's are different to Series 2 / 1000's
cortina wheels will go on an MM It's got teeth |
| Author: | simon k [ Wed Jul 23, 2008 10:54 pm ] |
| Post subject: | |
spraycanmansam wrote: simon k wrote: depends which minor... MM's are different to Series 2 / 1000's cortina wheels will go on an MM It's got teeth then I think you need to look to cortinas (and escorts I guess) MM -
1000 - |
| Author: | david rosenthal [ Thu Jul 24, 2008 1:00 am ] |
| Post subject: | |
How soon do you need them. I know of a low light morry with either 5" or 6" x 13" rims on it. It is in a country wrecking yard that I will be visiting soon . Can check them out and let you know. The one in my pic had 7" and 8" x 13" holden stud pattern with 289 ford |
| Author: | spraycanmansam [ Thu Jul 24, 2008 12:03 pm ] |
| Post subject: | |
In the next week and a half. Are they steels? The Morrie's got 13" 'hot-wires' on it atm, I hate 'em! Freight might be a biatch tho... |
| Page 1 of 1 | All times are UTC + 10 hours |
| Powered by phpBB® Forum Software © phpBB Group http://www.phpbb.com/ |
