oil leak
https://www.ausmini.com/forums/viewtopic.php?f=2&t=44251
Author:  mini_me [ Sun Jul 27, 2008 8:35 am ]
Post subject:  oil leak
Whilst changing the rubber cones and with radiator out
I noticed there is an oil leak around the timing cover.
I may as well change the gasket and seal while I have acess.
Question is how hard is the bottom pulley and bolt to get out
felix
Author:  sports850 [ Sun Jul 27, 2008 8:40 am ]
Not too difficult , locking the crankshaft so you can get enough oomph onto the bolt to undo it and retighten it afterwards is the key . Once the bolts off the pulley should lever out gently . Replace the seal as well as the gasket and you'll have no problems .
Author:  drmini in aust [ Sun Jul 27, 2008 10:09 am ]
One easy way to undo the bolt is put a bar and socket on it, lean the bar back against the bulkhead and kick the starter, WITH THE COIL H/T LEAD OFF.
To align the seal properly with the crank on assembly, fit the cover and gasket, do bolts up loosely. Fit crank pulley temporarily into seal, wiggle the cover on the bolts, then tighten them. Remove pulley if needed to get to the bottom ones.
If you don't do this the seal and pulley may be misaligned, then the seal will leak before its time.
To hold the motor while tightening the bolt, select 4th gear then have someone hold the brakes on HARD. :wink:
BTW I no longer fit those crappy locktabs, I use Loctite 262 on the thread instead. Never had one come loose since.
Author:  mini_me [ Sun Jul 27, 2008 11:17 am ]
Thanks guys that will be tomorrows job when I buy some new seals.
Just went to compress the new rubber cones in,
but realised that the thread in the new cones is courser.
Went to Bunnings and Mitre 10 to buy some brooker rod(threaded rod)
but no one seems to have the right size.Looks like I have to buy the right tool for this job. The 1/2 inch rod that they have is a sloppy fit.
Now I am getting frustrated.
Felix
Author:  Mick [ Sun Jul 27, 2008 11:41 am ]
A bolt supplier should be able to help you with the booker rod. Keep at it, it will all be worth it!
Author:  Wombat [ Sun Jul 27, 2008 11:51 am ]
Your newer cones are probably metric - make sure take a cone with you. Also get high tensile rod
