It is currently Sun Aug 03, 2025 9:42 pm
 Post subject: rod change length
PostPosted: Sat Aug 02, 2008 12:08 pm
is there different length rod change mechanisms?
put a A+ rod change into my roundy which previously had a remote chnage, and it seems like the selector should be longer so it can fit properly.
the bracket on the end of the selector looks like it is supposed to go straight up but if i have it like that the bolts are where the whole for the shifter is, everything looks like it needs to me 50-100mm further back.
the adjustment that can be done to lengthen the rods is already as far as it can go from what i can tell.
sorry if you cant understand what ive said i cant think of a better way to explain it, will get some pictures which will be able to do the talking
PostPosted: Sat Aug 02, 2008 12:40 pm
Mokes have shorter rods for the selector
PostPosted: Sat Aug 02, 2008 3:12 pm
measured and its roughly 65cm from the coupling that attatches to the box to the end of the selector housing, is this the right one?
PostPosted: Sat Aug 02, 2008 6:13 pm
I have a late rod change shifter (A+) on an aussie A engine, no problems.
Look into the moke option.
:D
PostPosted: Sat Aug 02, 2008 6:38 pm
you wouldnt be able to measure how long it is?
engine is from mini king and came out of a half cut so you would assume the rod change mechanism is the one out of the half cut but you never know
PostPosted: Sat Aug 02, 2008 8:27 pm
A Moke one is heaps shorter, much more than 100mm.. I know this because I cut a late Clubby one down to fit and welded it back together. :P
PostPosted: Sat Aug 02, 2008 9:29 pm
The Mini King
There should be no difference between the Aust And The Uki rod change, They were all made in the Uki< However the auk did use a different mounting at the rear, I think you may have a copy of our catalogue, If so have a look at page 110 item 13 is what we used here and item 19 is what was used in the UK, Give me a call if you like we will sort it out for you at no cost.
Best Regards
John
PostPosted: Sun Aug 03, 2008 4:29 am
havent got a catalogue forgot to get one when i was up there the other day, someone able to post pics?
if not ill give john/someone a ring when i get the chance
PostPosted: Sun Aug 03, 2008 3:06 pm
The Forkmeister
Hi Wilo, John ask me to post a couple of pic's off pg 110 of his book, I hope these are the right ones, Cheer Gerg
May the fork be with you.
PostPosted: Sun Aug 03, 2008 3:19 pm
There are two different length rod changes.
Carby version is the same as OZ cars.
EFI ones are approx 1" longer
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Sun Aug 03, 2008 5:04 pm
its has the UK #19 bracket
you can see the adjustment bolt to me looks like it is supposed to be in the cutout for the shifter judging by the bend etc
something tells me it isnt supposed to be sitting that low under the car
[/img]
PostPosted: Sun Aug 03, 2008 5:34 pm
The Mini King
I have note that Steve from Brickworks advised that there where two lengths of rod change fitted to the UK minis, And I am sure he would Know, Please call me on Monday and I will send you a Australian type rear mount and a complete rod change from an Australian Mini
Best Regards,
John Smidt
PostPosted: Sun Aug 03, 2008 5:52 pm
As long as it has an Australian front frame in it...
 Post subject: Re: rod change length
PostPosted: Sun Aug 03, 2008 7:33 pm
the remote and rod are different lenghts i think, i had to make the hole longer towards the back when i went to remote change
PostPosted: Mon Aug 04, 2008 1:11 pm
Best Regards,
John Smidt
ill come up on wednesday or thursday and bring the current selector so it can be compared to an aussie one.
Users browsing this forum: timmy201 and 90 guests
