It is currently Mon Aug 11, 2025 12:00 pm
PostPosted: Wed Aug 06, 2008 8:46 pm
Does anyone have a step by step procedure on installing a KAD quickshift (lift up collar) on rod change gearbox?
have one and its been gathering dust and thought its about time to install and try it.
PostPosted: Wed Aug 06, 2008 8:57 pm
I bought one 11yrs ago, have they changed the design?
PostPosted: Wed Aug 06, 2008 9:47 pm
should be really straightforward
PostPosted: Thu Aug 07, 2008 2:38 am
1. remove the knob off the old stick
2. push down and twist to take the cup off the top of the shifter box
3. remove the stick
4. Take the cup, nylon cup and spring off the old stick
5. Put the spring, nylon cup and cup on the new stick
6. insert the new stick in the shifter box
7. push down and twist to put the cup onto the shifter box
8. put knob on new stick
PostPosted: Thu Aug 07, 2008 4:33 pm
this is the one I've got with the knob already
how do you "remove" the stock stick off the shifter box? is it a roll pin or bolts holding the stick?
PostPosted: Thu Aug 07, 2008 6:17 pm
3. remove the stick
PostPosted: Thu Aug 07, 2008 6:19 pm
Wow they did change the design!!!
PostPosted: Thu Aug 07, 2008 7:59 pm
this is the newest model
:shock:
different colour is a big change!!!
PostPosted: Thu Aug 07, 2008 8:11 pm
Mine looks nothing like that. Its chrome though, supplied without a knob.
PostPosted: Thu Aug 07, 2008 9:45 pm
Hi,
I have fitted one before (Old KAD).
Once you twist the cup at the bottom and remove the original stick, you will then need to knock out the two rolled pins in the original housing with a centre punch (being carefull not to munt the alloy housing! :oops: ). Then the two new screws that come with the KAD gearstick in the new alloy collar screw into these holes. Be sure to keep the two rolled pins, incase you want to remove it later and replace to original. :)
I have not included in the above instructions where you smash your fingers with the mallet and drive the centre punch into your knee!
Best of luck...
One thing I have always wondered is whether these quickshifts quickly shift your syncro's into the rubbish bin?
PostPosted: Thu Aug 07, 2008 9:49 pm
The quickshift only shifts the fulcrum point of the gearstick. Unless your not using your clutch or flat changing i cant see why it would destroy synchros.
PostPosted: Thu Aug 07, 2008 9:52 pm
If you force the gearbox to make quicker shifts (quickshift? :lol: ) it will screw the syncros. They only work at a set speed. It does not matter what gearchange you have you can still break the syncros, but with a quickshift you can do it easier.
PostPosted: Thu Aug 07, 2008 10:00 pm
MMmmm!
I thought the quickshifts might do it faster too!
Regardless, they feel nice when swapping gear and bring the stick closer to the driver...just don't rush it too much has always been the key to making gearboxes last. :)
PostPosted: Sat Aug 09, 2008 11:19 am
its not really a "quickshift" its a "shortshift"
PostPosted: Fri Aug 15, 2008 5:18 pm
whats the easiest way to removing the rolled pin on the house?
I tried removing this but no space for my pin punch and it'll be on an angle...
Users browsing this forum: Bing [Bot] and 88 guests
