Two Problem! https://www.ausmini.com/forums/viewtopic.php?f=2&t=44672 |
Author: | henry the mini [ Sat Aug 09, 2008 10:19 am ] |
Post subject: | Two Problem! |
Hello all, i have two problem with the little car at the moments. 1st Brake: They make the car shake like mad, any idea what can cause that. I was thinking wheel alignments, but it's not that. Wrap disk....maybe!!!! 2nd: Is it normal to have intermittent windscreen wiper, i mean some time they work and sometime they don't ![]() Any help greatly appreciated Louis |
Author: | jasonf [ Sat Aug 09, 2008 12:34 pm ] |
Sounds like your discs are ready for replacement or a grind...warping generally causes that, you probably notice it more with speeds over 60kph..... Wipers, well I am definately no electrical expert, but could be a bad earth, or could be internal.....will leave that for someone that knows more ![]() |
Author: | BALLISTIC [ Sat Aug 09, 2008 12:35 pm ] |
Possibly warped discs, may even be out of round drums. More to the point when does it do it? could be wiper switch or the motor requires re-winding/replacing but first will need to be tested. |
Author: | 9YaTaH [ Sat Aug 09, 2008 1:02 pm ] |
Post subject: | Fr? Rr? |
or something loose or broken in your front end...get it looked at quick. |
Author: | Wombat [ Sat Aug 09, 2008 1:05 pm ] |
2nd: Is it normal to have intermittent windscreen wiper, i mean some time they work and sometime they don't Just like my indicators - they work -they don't - they work - they don't - they work .............. Sorry couldn't help it ![]() |
Author: | BALLISTIC [ Sat Aug 09, 2008 2:54 pm ] |
Wombat wrote: 2nd: Is it normal to have intermittent windscreen wiper, i mean some time they work and sometime they don't
Just like my indicators - they work -they don't - they work - they don't - they work .............. ![]() I ![]() ![]() |
Author: | henry the mini [ Sat Aug 09, 2008 8:09 pm ] |
BALLISTIC wrote: Possibly warped discs, may even be out of round drums. More to the point when does it do it?
could be wiper switch or the motor requires re-winding/replacing but first will need to be tested. The brake are really bad at high speed, make the car shake, but visually the disk look very good!!! |
Author: | d1ck0 [ Sat Aug 09, 2008 8:35 pm ] |
henry the mini wrote: BALLISTIC wrote: Possibly warped discs, may even be out of round drums. More to the point when does it do it? could be wiper switch or the motor requires re-winding/replacing but first will need to be tested. The brake are really bad at high speed, make the car shake, but visually the disk look very good!!! |
Author: | BALLISTIC [ Sat Aug 09, 2008 9:34 pm ] |
henry the mini wrote: The brake are really bad at high speed, make the car shake, but visually the disk look very good!!!
Author: | henry the mini [ Sun Aug 10, 2008 10:11 am ] |
BALLISTIC wrote: henry the mini wrote: The brake are really bad at high speed, make the car shake, but visually the disk look very good!!! ![]() The second option, when above 60k's the brake pedal and pulsate as you said, i am due for new disk am i???? |
Author: | Mike_Byron [ Sun Aug 10, 2008 10:40 am ] |
Louis jack the car up one side at a time (very safely of course) and shake the wheel to see if there is any movement up or down or forward and back. You are looking for a loose wheel bearing, worn ball joints, worn tie rod rubbers etc. Then if all is tight check the brakes. There should be any movement beyond normal suspension movement. It could also be a worn tie rod ball joint. Mike |
