mini rotisserie https://www.ausmini.com/forums/viewtopic.php?f=2&t=44686 |
Page 1 of 2 |
Author: | Leighton [ Sat Aug 09, 2008 8:01 pm ] |
Post subject: | mini rotisserie |
does anybody have a 'how to' on mini rotisserie??? cheers leighton |
Author: | Leighton [ Sat Aug 09, 2008 10:33 pm ] |
aaaanyone??? oh can it be done on a '75 clubby |
Author: | simon k [ Sat Aug 09, 2008 10:40 pm ] |
did they still have the hole in the firewall on a '75 - makes it much easier I made one for my van, and in all honesty, I reckon you're best off working it out for yourself - work out where you'll mount it, what steel you need, then zap it together... |
Author: | d1ck0 [ Sat Aug 09, 2008 10:42 pm ] |
simon k wrote: did they still have the hole in the firewall on a '75 - makes it much easier 75 will be borderline. My 76 Doesnt, but I'm not sure when they stopped it officially.
Dicko |
Author: | Leighton [ Sat Aug 09, 2008 10:47 pm ] |
im pretty sure its got a hole just patched up with a circular plate maybe riveted. i picked up two engine stands today. would a steel pole between the stands work??? cheers leighton |
Author: | rainbowpython03 [ Sat Aug 09, 2008 10:48 pm ] |
Ive boiled two minis, but ive never roasted one! Sorry had to be said, im over it now ![]() |
Author: | simon k [ Sat Aug 09, 2008 10:49 pm ] |
Leighton wrote: im pretty sure its got a hole just patched up with a circular plate maybe riveted. i picked up two engine stands today. would a steel pole between the stands work???
cheers leighton yep, a few people have done that and apparently it works well.... mine is made out of 50mm RHS |
Author: | Leighton [ Sat Aug 09, 2008 11:00 pm ] |
Quote: Ive boiled two minis, but ive never roasted one! Sorry had to be said, im over it now lol Quote: yep, a few people have done that and apparently it works well.... mine is made out of 50mm RHS
ok, sounds good. what do i actually need to do to attatch the spit to the mini? do i need to bolt a bracket to the firewall with a hole in it or......any ideas??? cheers leighton |
Author: | Mick [ Sat Aug 09, 2008 11:01 pm ] |
cheers leighton I did just this. I then bought a length of steel tube with the correct O/D and slid it through. I length of 2x1 square tube was cut to length and drilled so that a bolt went through each of the rear shock mounts in the boot, and the subframe tower mounts in the front. Also drilled these so a pair of u-bolts straddle the pipe and are bolted through the cross pieces. Took about and hour to make once I had all the pieces lying on the floor. The engine stands are a little too low however, they need an extra 6-12 inches to be perfect imho. |
Author: | ronhic [ Sat Aug 09, 2008 11:17 pm ] |
...that's going to take a lot of charcoal and basting.... mmmm....where do you get a Tupperware container big enough to marinate a mini in??? K |
Author: | Leighton [ Sat Aug 09, 2008 11:21 pm ] |
are the engine stands that low that it wont work or its very close and risky??? Quote: ...that's going to take a lot of charcoal and basting....
mmmm....where do you get a Tupperware container big enough to marinate a mini in??? K the tupperware shop ![]() |
Author: | niffty64 [ Sun Aug 10, 2008 7:13 am ] |
I used this plan to base my mini BBQ on. http://joltfreak.tripod.com/id50.html I like mine well done this one is a liitle under done ![]() ![]() ![]() ![]() hope it helps |
Author: | Mick [ Sun Aug 10, 2008 8:22 am ] |
Leighton wrote: are the engine stands that low that it wont work or its very close and risky??? They will do the job, only as you rotate the mini it will get to about 70 - 80 degrees and the sill will touch the ground. It's fine enough to work under the car, but not perfect. Cut and shut the vertical support on the engine stand with some identical square section and you will be able to flip the car over.[/quote] |
Author: | drmini in aust [ Sun Aug 10, 2008 8:37 am ] |
That one looks good but put some decent castors on it then you can move it about... like these- Front mount detail- It comes apart for transport, I brought it all home in an EA Falcon sedan... |
Author: | mini_fly [ Sun Aug 10, 2008 8:42 am ] |
Here are some plans for one... http://starchak.ca/tech/mini_rotisserie.htm |
