Lifting bracket https://www.ausmini.com/forums/viewtopic.php?f=2&t=4470 |
Page 1 of 2 |
Author: | Wombat [ Tue Feb 01, 2005 3:18 pm ] |
Post subject: | Lifting bracket |
Anyone have a diagram with measurments for an engine lift bracket? |
Author: | 1310/71 [ Tue Feb 01, 2005 3:32 pm ] |
Wombat, See the thread entitled "Best Method". This is exactly the question I asked before making one myself last week. I can measure mine and post tonight when I get home. It was just a bit of angle iron cut and drilled in the right spots, with a D bolt shackle welded on for the loop. A few other people posted with other options also. Kevin. |
Author: | Wombat [ Tue Feb 01, 2005 3:39 pm ] |
That's what I was looking form and couldn't remember the thread ![]() |
Author: | 1310/71 [ Tue Feb 01, 2005 7:14 pm ] |
I'm very much an amateur in the garage but this is the one I made last week with rough dimensions. If you have the Mini handy it's quite easy to drill the holes; if it doesn't quite fit, go up 0.5mm in drill size or file it a bit etc As you will see the D shackle is welded offset towards the flywheel end (it mounts back to front on the head compared to the photo) Now the engine's out, I might even sandblast and paint the bracket! ![]() Hope this helps Kevin. |
Author: | justminis [ Tue Feb 01, 2005 8:20 pm ] |
Kevin, nice work, how is the balance of the motor with the dimensions of your bracket? Steve |
Author: | 1310/71 [ Tue Feb 01, 2005 9:12 pm ] |
Pretty good - the Doc gave me the heads up about offsetting it towards the flywheel ![]() ![]() Pretty simple to make. Cut some angle, drill it. Carve out the centre bit to clear #3 stud (counting from the radiator side), then weld a hook on (or get someone to if you don't have a welder). In my case I got a D shackle and hacksawed the eyelets off before welding it on. KB |
Author: | gafmo [ Tue Feb 01, 2005 9:22 pm ] |
Don't lose that...you will need t again.. ![]() Just hang it where you can see it.....Sand blast it ![]() ![]() |
Author: | J_A_M [ Tue Feb 01, 2005 9:52 pm ] |
great pic KB....is that your own handy work? |
Author: | Wombat [ Tue Feb 01, 2005 10:27 pm ] |
Good pic Kevin - Now I have to get the welder back from my son in Rocky |
Author: | drmini in aust [ Tue Feb 01, 2005 10:29 pm ] |
Wombat wrote: Good pic Kevin - Now I have to get the welder back from my son in Rocky
Don't be a cheapskate- just go buy another! ![]() ![]() |
Author: | Wombat [ Tue Feb 01, 2005 10:30 pm ] |
Ya a nice MIG - ![]() |
Author: | drmini in aust [ Tue Feb 01, 2005 10:37 pm ] |
Wombat, Stick weld is stronger weld than a baby MIG one , on angle iron and round bar..! You don't want it to come off.. BTW Kevin I would weld right round yours, don't just tack it... ![]() |
Author: | 1310/71 [ Wed Feb 02, 2005 7:04 am ] |
drmini in aust wrote: Wombat,
Stick weld is stronger weld than a baby MIG one , on angle iron and round bar..! You don't want it to come off.. BTW Kevin I would weld right round yours, don't just tack it... ![]() Doc, I'll bow to your greater experience and have another go at it. I did get pretty good penetration though (oooaahhh). It's pretty much welded all around the "shafts" I'll post a close up shot tonight for the gang to critique. Anton - Yes I made it myself and I'm a Food Scientist!! Edit - I use a Transmig 130 I bought about 10 yrs ago. ![]() |
Author: | J_A_M [ Wed Feb 02, 2005 7:45 am ] |
1310/71 wrote: Anton - Yes I made it myself and I'm a Food Scientist!!
Author: | Wombat [ Wed Feb 02, 2005 8:37 am ] |
Hey Doc ANY excuse to buy another toy ![]() ![]() |
