Hydrolastic Pump - Sealing Up The Reservoir https://www.ausmini.com/forums/viewtopic.php?f=2&t=44727 |
Author: | matt van'74 [ Sun Aug 10, 2008 9:07 pm ] |
Post subject: | Hydrolastic Pump - Sealing Up The Reservoir |
Gday all, I picked up an original Hydrolastic Pump today. Bringing it home I got the typical response. "What is it? How much did you pay for it? Is it meant to be that rusty" Parents never understand ![]() However, the reservoir has a quite a few minor rust holes in it. I have heard of people using a sealant which you put in fuel tanks to seal them up. Does anyone know of any products that I could attempt to use to seal the reservoir with? If it doesnt work I will attempt to solder them up or salvage the old fittings and solder them into an old rectangular oil container I have (after claeaning it ofcourse) If all else fails I will just use a plastic container of some sort. Cheers Matt |
Author: | jasonf [ Sun Aug 10, 2008 9:19 pm ] |
If only small holes you could try the por15 fuel tank repair kit... http://www.ppc.au.com/kits3.htm |
Author: | Morris 1100 [ Sun Aug 10, 2008 9:24 pm ] |
A lot of the car restorers use Red-Kote fuel tank liner. There is an advert for it in Restored Car magazine. Or take a look at this ebay advert. |
Author: | matt van'74 [ Sun Aug 10, 2008 9:41 pm ] |
Thanks for the advice ![]() I will look into them. Matt |
