It is currently Fri Jul 18, 2025 3:57 pm
PostPosted: Tue Aug 12, 2008 5:15 pm
Hi
motor has been pulled out of my fathers mini and we are going to repair that motor because there is too much fiddling to get a rod change (my blue crashed mini motor) into a remote change car with changing the hole etc.
Anyway wanting to know what is the best / easiest way of connecting the rubber crosses after engine has been lowered back in.
Thanks Brenton
PostPosted: Tue Aug 12, 2008 5:25 pm
High heel ninja
Insert U bolt, tighten up nuts,
Repeat process.
You can easily fit a rod change to a remote vechile, invloves drilling a hole & welding/bolting in a peice of flat steel.
Doogie
PostPosted: Tue Aug 12, 2008 5:32 pm
Sorry i didnt explain myself properly. :oops:
i mean how do i reposition the rubber crosses into the claws with the motor in. Ie rather than pulling whole wheel assembly off and pushing them back together
(hope that makes sence)
 Post subject: Crack it
PostPosted: Tue Aug 12, 2008 5:44 pm
Yes it does...but most people line up the drive shaft couplings when they are installing the engine...it may be easier to crack a ball joint to give yourself some room to manouvere at this stage.
Users browsing this forum: Bing [Bot] and 88 guests
