It is currently Sat Aug 02, 2025 9:52 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2, 3  Next
 Post subject: Mini down and out...
PostPosted: Wed Aug 13, 2008 6:45 pm
...And so close to Mini Muster!!!! :evil:
Dramas today with selecting 3rd and 1st gear when the car is on or off, clutch in or out - it makes no difference.
When trying to select 1st or 3rd, it's like the 'H' pattern has gone and is now just an 'n' (only with 2nd and 4th...also with reverse being able to be selected).
Mechanic reckons engine, clutch, firewall and all sorts of crap needs to come out to get the gearbox out...so right now i'm not a happy girl!!
He said there could be a loose bolt or something to do with the selector which is causing the problem.
Hopefully will have everything sorted in time for Mini Muster...or else i'm bringing it on a trailer :P...no way i'm missing out!
PostPosted: Wed Aug 13, 2008 6:49 pm
The Mini King
Hi, Is This a rod change or remote gear change
PostPosted: Wed Aug 13, 2008 7:06 pm
erumm.. how do i tell them apart.. sorry for the noob question my boyfriend is NO HELP!
hes a hoon and is only interested in my car if i mention turbo at the start.
PostPosted: Wed Aug 13, 2008 7:16 pm
A rod change will have 2 rods going from the g box to the stick,
A remote will have an alloy housing running back instead :wink: .
Easy to tell once you know. Oh you will have to lie down and look under the car :wink: .
If your avatar is of your car, then it being a Clubman, it is most likely to have a rod change and this leads to a couple of possibilities for the loss of 1st and 3rd, neither of which are a great drama. It would be a shame for you to miss the muster so if you need someone to help you out, there are plenty of us ausminiers in Brisbane and one of us, including myself, should be able to offer some help. PM if needed.
1964 998 Cooper , 1968 Morris 1100
PostPosted: Wed Aug 13, 2008 7:22 pm
do you have to lift the lever up to get into reverse? or just knock it across?
yes thats my baby in the picture.
oh sweet as atleast i know its a rod change.
help would be great... any idea of the possibilities off the top of ur hat what the dramas would be???
thanks
PostPosted: Wed Aug 13, 2008 7:26 pm
mine just knocks across
 Post subject: Re: Mini down and out...
PostPosted: Wed Aug 13, 2008 7:28 pm
you'll need to lift the engine out (and take the clutch off) to get at the gearbox, but you most certainly do NOT need to remove the firewall!!!
get on to your local ausminiers and they will help you out. put on a barbie for them or something :wink:
78 Leyland Mini - Prince
PostPosted: Wed Aug 13, 2008 7:43 pm
this means it's a remote change, does it not, experts?
PostPosted: Wed Aug 13, 2008 7:50 pm
yep no lift usually tells us its a remote change and it may just have a loose knunkle jhoint at back if its 1st and 3rd, thinks maybe if you are close enough a call to the Miniman might save a lot of work and money :D
PostPosted: Wed Aug 13, 2008 7:54 pm
No. It could just be a worn out rod-change or sometimes the driver does not realise that they are actually lifting the lever to get reverse.
PostPosted: Wed Aug 13, 2008 7:57 pm
Ditto, mine has a rod change (although I think it may have originally been remote? - 71 clubbie). My lift is so barely recognisable, I would also say mine is a knock across if asked.
KB
PostPosted: Wed Aug 13, 2008 8:14 pm
The Mini King
Remove the gear lever boot, if you can see two screws holding the gear lever in place, if so then it is a remote type, if there is a metal retaining cup then it is a Rod Change, If it is a rod change, then remove gear lever and check the slot in the side near the bottom, this should have parallel sides if there is a wear mark in this area then it POSSIBLE that this could be your problem
PostPosted: Wed Aug 13, 2008 8:21 pm
Kirsten...you need to acquaint yourself with a Mini expert up your way...get some advice on what the problem is..
http://www.ausmini.com/forums/viewtopic.php?t=10543
another idea might be to check out the local Mini Car Club..they can be helpful as well.
EDIT: Gawd!! and maybe someone from AUSMINI could come around and have a geek
Good Luck, Mick :roll:
Users browsing this forum: fuzzy-hair-man and 85 guests
