It is currently Wed Aug 06, 2025 2:20 pm
PostPosted: Sat Aug 16, 2008 7:09 pm
hello minis blinkers stopped working just wondering where is the fuse for the blikers located and if the flasher box stopped working would the blinkers just illuminate and not flash or will the blinkers not work at all. my arnt working at all.
cheers TUCK3R
PostPosted: Sat Aug 16, 2008 7:12 pm
If the flasher can goes the lights will come on and not flash. usually... :lol:
But if the contacts in there are burned out it's possible no flashers come on..
PostPosted: Sat Aug 16, 2008 7:14 pm
is the flasher can the thing that is a clylinder shape ? and is there a fuse i can check im not getting nothing at all?
cheers TUCK3R
blinker fuse that sometimes messes up on mine is on driver side on the side wall like above the washer bottle, should have a cover on it.
Not sure if there is another inline fuse??
and i think blinker will not work at all if was flasher box
Brenton
PostPosted: Sat Aug 16, 2008 7:40 pm
Yep it's fed from the bottom fuse (switched). :wink:
PostPosted: Sat Aug 16, 2008 8:06 pm
PICTON in what state?
Noli Illegitimi Carborundum
PostPosted: Sat Aug 16, 2008 8:07 pm
ausmini mod
ausmini mod
You should be able to test it with a battery ... instead of the flasher.
I would take it off and check it.
Pete
PostPosted: Sat Aug 16, 2008 8:08 pm
NSW, circa mid 1950s
PostPosted: Sat Aug 16, 2008 8:16 pm
well if he wants to drive 4000km to picton WA I can lend him a flasher pot...
PostPosted: Sat Aug 16, 2008 8:17 pm
If the can is a dud get an electronic one, they are more reliable. :wink:
PostPosted: Sun Aug 17, 2008 2:56 pm
hey i fixed it i stuck a piece of wire where the flasher cam connects into the wiring and it turned blinkers on so i put a new flasher cam in it and the one that stuffed up was electronic.so i payed 5 dollars and fitted a new one. i think the new one i put it isnt electronic cause its delayed when i hit the switch it takes a second to react. but its still better than a fine and loss of points. thanks for all the advice and help.
Cheers TUCK3R
