It is currently Thu Aug 14, 2025 9:22 am
PostPosted: Tue Aug 19, 2008 9:35 pm
Can you fit competition rear bumps stops for a hydro car to the rear of a dry mini?
If i can, i'm planning to use them to minimise the weight transfer to the rear of the car, hopefully these will stop the rear squatting under acceleration.
PostPosted: Tue Aug 19, 2008 9:37 pm
Yes you can, there are instructions in the packet how to fit on a dry car. :wink:
You have to drill & taps some holes to mount them, also move the brake pipes away from the top and secure them with some hoseclamps.
PostPosted: Tue Aug 19, 2008 9:51 pm
Can you get in there with everything still together or do you have to remove the trailing arm?
Does the car sit on them permanently?
PostPosted: Tue Aug 19, 2008 9:53 pm
You can do it in situ, on the car.
How high it sits depends on your rear suspension's height setting.
If low, yes it will sit on them but they are an aeon rubber spring, they can handle a bit of load.
PostPosted: Tue Aug 19, 2008 9:57 pm
There's some discussion about doing it in here Josh from when I posed the question before .
http://www.ausmini.com/forums/viewtopic ... ompetition
PostPosted: Tue Aug 19, 2008 10:08 pm
fuel tank out job though.... you'd need to undo the shockers to let the radius arms all the way down
PostPosted: Tue Aug 19, 2008 10:14 pm
Thanks Kev and Ian, Simon - i think i can do it with the tank in place :P
 Post subject: Ohhh?
PostPosted: Tue Aug 19, 2008 10:20 pm
Yeah...but get an earth on that battery or you won't be going nowhere :D
PostPosted: Tue Aug 19, 2008 10:21 pm
yeah.... righto... :roll:
:lol:
PostPosted: Tue Aug 19, 2008 10:44 pm
High heel ninja
So hows Emmaline gunna fit in the boot with that in her way?
Doogie
Users browsing this forum: Bing [Bot] and 291 guests
