New How To https://www.ausmini.com/forums/viewtopic.php?f=2&t=45020 |
Author: | 1018cc [ Wed Aug 20, 2008 5:04 pm ] |
Post subject: | New How To |
Just thought I'd bring everyone's attention to a new how to that has magically appeared in the how to forum. http://www.ausmini.com/forums/viewtopic.php?t=44556 I did this the other day, I posted this in the porno room and simonk said that he usually takes the carbs off the heatsheild and then removes the heatshield. You guys can choose whichever way you want to do it but that's just the way that I did it. I hope it helps out some of you n00bs hoping to break into mini maintenance. This is a really easy job that most people should be able to handle as long as they have the right shape spanners etc. Cheers, Nick |
Author: | chopchop [ Wed Aug 20, 2008 5:23 pm ] |
nice one nick, thats a job i need to do |
Author: | 1018cc [ Wed Aug 20, 2008 5:27 pm ] |
chopchop wrote: nice one nick, thats a job i need to do
Well I hope you find it useful chop. It is one of those things you should check - I started packing sh*t once I saw fuel leaking onto my extractors ![]() ![]() Just make sure you have a ring / O/E spanner with enough S curve on the end of it to get to the bolts but still miss the heat shield. BTW, my heat shield is off of a morris minor so that could make it easier / more difficult than a mini one. |
Author: | 1018cc [ Thu Aug 21, 2008 8:34 am ] |
There is multiple ways of doing this so here are another couple: BALLISTIC wrote: Nice how to, just thought i'd offer up some of my knowledge/experiences to you in this area of mini fun ![]() ![]() ![]() ![]() ![]() For a std inlet/exhaust manifold the normal manifold gasket is fine because there are no height differences (in theory)at the mounting points so you are getting a more even pressure at the mounting points. ![]() Please note that these are my findings and opinions of which you are more than welcome to ignor, have a difference of opinion or take on board. Cheers simonk wrote: I find the easiest way to take them off is to take the carbs off the manifold, and then the manifold off the motor. I do this because I hate undoing the choke and accelerator cable, and because it's easier to get to the manifold nuts to make sure they're done up properly.
If you take the carbs off the manifold, the accelerator cable stays in the linkage, and dangles off the manifold, and the choke cable stays attached to whichever carb it's attached to. You just poke that carb somewhere in the engine bay... As for the accelerator cable staying on it's linkage, it's (supposed to be) a fairly exact science to set the position of the linkage, with the cable installed, so the carbs open at the same time - leaving it attached to the cable means this doesn't need to be reset when you put them back on the manifold, it's just a matter of balancing the linkages on one carb, putting the other one up to it and holding the linkages between them, and shoving them on the manifold ![]() so that's just what I do, doesn't mean it's better, or right... I'll put these here, even though I have an 'edit' button on my post I can't actually edit it once it's in the How To forum. |
