Engines according to me https://www.ausmini.com/forums/viewtopic.php?f=2&t=45052 |
Author: | WantOne [ Thu Aug 21, 2008 6:57 pm ] |
Post subject: | Engines according to me |
I'm trying to work a few things out. I've got a new 202 head and want to know if it will do anything. I'm an electrician so I have a small clue about stuff mechanical but it's not my day job. Please correct me if this sounds like poo. It's an A Series 998. Now.... it smokes on deceleration and under hard load. So I figure the vacuum in the cylinders is pulling oil up and through/around the worn out rings burning and causing the smoke. But the rings aren't worn enough to smoke at idle. Compressions are fair at 100-115, that tests the valve seals, correct? So I figure changing the head is a silly idea unless I do the pistons and rings too. If this sounds like total BS please tell me. |
Author: | AEG163job [ Thu Aug 21, 2008 7:08 pm ] |
Sounds to me the oil control rings are out to lunch. Which means a full strip, so most sensible people would check other items like big-ends, valves, guides & seals etc. whilst its in pieces. How many kays since last re-build? |
