Time delay https://www.ausmini.com/forums/viewtopic.php?f=2&t=45116 |
Page 1 of 3 |
Author: | Wombat [ Sat Aug 23, 2008 8:28 pm ] |
Post subject: | Time delay |
I'm putting together a small cuircuit to delay ignition on after I push the starter so the engine is spinning nicely before the electonic distributor fires off a spark. Anyone like to guess at how long the starter should run before the engine can fire? |
Author: | Mick [ Sat Aug 23, 2008 8:31 pm ] |
Subaru WRXs have a deliberate delay of about 1 - 1.5 seconds before they allow a spark to be generated....I dunno why in their case, but am told it is so.... |
Author: | sgc [ Sat Aug 23, 2008 8:42 pm ] |
Post subject: | Re: Time delay |
Wombat wrote: Anyone like to guess at how long the starter should run before the engine can fire?
Assuming your fuel system is performing properly, I wouldn't have thought you'd need more than a couple of crank revs. My 123 kicks off the starter on the first or second power stroke, it's a damn pain in the ass.. almost never get it started first go without dampening the spark with the choke. Couple of revs would be enough I think... enough to get some momentum up. |
Author: | 1071 [ Sat Aug 23, 2008 8:42 pm ] |
One and half seconds...geeze Nora - a properly tuned Mini should fire immediately the key is turned. Cheers, Ian |
Author: | woodwormm [ Sat Aug 23, 2008 8:45 pm ] |
would love to see a how to on this delay circuit. good luck |
Author: | Morris 1100 [ Sat Aug 23, 2008 8:47 pm ] |
It really only needs to skip firing one plug, so half a second could do it. |
Author: | gafmo [ Sat Aug 23, 2008 9:09 pm ] |
why David ![]() |
Author: | Drekkus [ Sat Aug 23, 2008 9:13 pm ] |
Wombat wrote: I'm putting together a small cuircuit to delay ignition on after I push the starter so the engine is spinning nicely before the electonic distributor fires off a spark.
Anyone like to guess at how long the starter should run before the engine can fire? I was looking at something like this and modifing as necessary. http://www.jaycar.com.au/productView.as ... &SUBCATID= |
Author: | Morris 1100 [ Sat Aug 23, 2008 9:17 pm ] |
With a standard points ignition when you turn it over to start the motor it misses the first spark while the ignition builds up current and then it fires the second cylinder. With an electronic ignition like a Pulsar dizzy it will fire the first cylinder regardless. This means that if you are running a bit of advance on the ignition and your starter is a bit slow it will kick back when the first cylinder sparks because the crank is not spinning fast enough. By fitting a delay the crank will spin fully before the ignition fires the first spark. |
Author: | drmini in aust [ Sat Aug 23, 2008 9:32 pm ] |
With the Pulsar dizzy, I now have a switch wired into the ignition circuit, I spin the starter up for a few turns then throw da switch.. Before I did this mod, I broke 3 Lucas starter pinions, including 2 new ones... ![]() This 1360 runs about 16° static advance.... and needs it. ![]() The wife's 1293A+ also with Pulsar dizzy has a Gemini starter, it doesn't break pinions but it stalls the first rev or two when cold. BTW the Gemini starter KW rating is less than the Lucas... ![]() |
Author: | Drekkus [ Sat Aug 23, 2008 9:58 pm ] |
drmini in aust wrote: The wife's 1293A+ also with Pulsar dizzy has a Gemini starter, it doesn't break pinions but it stalls the first rev or two when cold.
Thats the problem I'm having.Fine when warm but cold it does have problems sometimes. I'm not particularly keen on a switch as my wife has taken to driving it and I have to keep things as simple as possible.This is a woman who refused to drive it initially as the speedo was in mph. |
Author: | drmini in aust [ Sat Aug 23, 2008 10:05 pm ] |
With the Gemini starter, just turn the key until the motor is running- being a pre-engaged type it can't throw the pinion out with isolated kicks like the Lucas always does. ![]() As for the speedo problem, put a 140KMH Moke one in. ![]() The one marked 800turns/km suits a 3.44 diff pretty well, the 860 turns/km one suits a 3.647 (Mini-K) diff and is spot on. Both these assuming with 10" wheels... ![]() |
Author: | Bubbacluby [ Sat Aug 23, 2008 10:13 pm ] |
drmini in aust wrote: the 860 turns/km one suits a 3.647 (Mini-K) diff and is spot on.
I thought mini K was a 3.44 diff and deluxe was 3.647? |
Author: | drmini in aust [ Sat Aug 23, 2008 10:17 pm ] |
Mini-K is 3.647, (I run 2 of em) Deluxe was 3.765. |
Author: | Mick [ Sat Aug 23, 2008 10:18 pm ] |
Bubbacluby wrote: drmini in aust wrote: the 860 turns/km one suits a 3.647 (Mini-K) diff and is spot on. I thought mini K was a 3.44 diff and deluxe was 3.647? Nope. Only Cooper S/LS/GT were 3.44 to compliment the 1275. |
Page 1 of 3 | All times are UTC + 10 hours |
