Boot seal clips https://www.ausmini.com/forums/viewtopic.php?f=2&t=45154 |
Author: | drmini in aust [ Mon Aug 25, 2008 10:39 am ] |
Post subject: | Boot seal clips |
OK there are 26 spring clips (new), I haven't fitted any of these for 30+ years, the last couple of times I just glued the seal onto the bootlid. What is the trick- do you put them all on the bootlid first and try to feed the seal along them, or push each one in whilst held into the seal? ![]() I have about 6 manuals, and not one covers it... ![]() |
Author: | graham in aus [ Mon Aug 25, 2008 10:44 am ] |
Last one I did Kev, I used the latter technique! ![]() I have heard people complain about this job, but I found it relatively straightforward? ![]() Might be some deal with having the right profile of seal and clip combo? Good luck! ![]() |
Author: | Mick [ Mon Aug 25, 2008 10:55 am ] |
I mounted the clips and tried to push the rubber on last time and regretted it. |
Author: | drmini in aust [ Mon Aug 25, 2008 10:57 am ] |
I am using a Karcraft seal, the sponge has a bigger hole than that from another western suburbs supplier so hopefully it won't need 5 people to close the lid the first time like Anton's did. ![]() |
Author: | Mick [ Mon Aug 25, 2008 11:24 am ] |
yep, had that problem too... |
