It is currently Sun Aug 10, 2025 12:35 am
Which looks better for the Mini
Poll ended at Sun Aug 31, 2008 6:04 pm
Type 1 - Black colour roundish 43%  43%  [ 6 ]
Type 2 - Grey 57%  57%  [ 8 ]
Total votes : 14
PostPosted: Tue Aug 26, 2008 5:41 pm
I'll be installing a 3rd brake for the mini as I think the stock are not sufficient for drivers that are day dreaming on the road.
Just got 2 from the wreckers as an aftermarket hella ones are the ones with stick on things that you stick on the glass that my mini doesn't have.
Just asking for opinions what looks better for the mini
TYPE 1 - Black single bulb
Needs to be mounted a little away from the edge as the plastic cover hits the edge?softop
or
TYPE 2 - Grey with 2 bulbs
Sorry 'bout the blurry mobile pics
Thanks in advance
PostPosted: Tue Aug 26, 2008 6:16 pm
The second one looks better.
What is it from?
Cheers Pete
PostPosted: Tue Aug 26, 2008 6:22 pm
Thats where I'm leaning towards to as the 1st one looks kinda out of place
the 2nd one is from a Hyundai sedan and the 1st one is from a Mazda Metro i think
I was in a hurry as I I had 10mins before the closing time
PostPosted: Tue Aug 26, 2008 6:27 pm
NAV-MAN
I like the 2nd one.
give it a good clean and get some plastic primer and the colour of your choice or if there is paint that will stick straight to plastic use that.
PostPosted: Tue Aug 26, 2008 6:31 pm
The 2nd one looks better.
Image Image
PostPosted: Tue Aug 26, 2008 6:49 pm
definately the 2nd one
PostPosted: Tue Aug 26, 2008 7:59 pm
2nd one looks good
PostPosted: Tue Aug 26, 2008 9:09 pm
I just tested both the lights and the 1st one is using a normal brake light bulb which is really brightand the 2nd one uses 2 wedge type T-10 size bulb which is worst than the mini 15 watts each
PostPosted: Tue Aug 26, 2008 9:34 pm
Second one here also.
But a Question do you travel around without the cover on the top only or will the window section be this low
PostPosted: Tue Aug 26, 2008 9:50 pm
they're both too big but go the 2nd one.
PostPosted: Tue Aug 26, 2008 9:53 pm
always off
PostPosted: Wed Aug 27, 2008 7:21 pm
I'll have a look again maybe tomorrow if theres a smaller one
it does look kinda big for the mini huh...
PostPosted: Wed Aug 27, 2008 7:24 pm
i think you should use an LED light bar..
PostPosted: Wed Aug 27, 2008 7:31 pm
something like this from the fleabay?
PostPosted: Wed Aug 27, 2008 7:34 pm
something like this:
http://www.ledspecialfx.com.au/media/uni_lightbar_orange.jpg
Users browsing this forum: Bing [Bot] and 91 guests
