Straight Cut Primary Gear https://www.ausmini.com/forums/viewtopic.php?f=2&t=45233 |
Page 1 of 3 |
Author: | Hanra [ Wed Aug 27, 2008 10:13 am ] |
Post subject: | Straight Cut Primary Gear |
Does anyone know who would stock a Pre A+ Straight Cut Primary Gear to suit a Small Bore? Has the same size bushes front/rear. |
Author: | Hanra [ Wed Aug 27, 2008 6:53 pm ] |
Any ideas? |
Author: | drmini in aust [ Wed Aug 27, 2008 7:10 pm ] |
Can't even find them on the Minispares UK site. ![]() Or MiniMania... You could use a 1275 one with a custom thicker front bush in it. ![]() |
Author: | Hanra [ Wed Aug 27, 2008 7:25 pm ] |
Ive been searching Mini Spares UK. Ive emailed them ill wait for a reply. I just started searching Mini Mania. But if you have looked Kev, sounds like they dont have em either... The issue is, the crank in my 1330 has had the lip machined off it where the 1275 larger primary gear rear bush ran. When i was rebuilding it in 2001/2, I could not source a 1275 primary gear in good condition. (the internet was in its infancy and im not sure Ebay existed). My only soloution was to machine the lip off and run the small bore primary gear as I had a good one from my 1098. |
Author: | drmini in aust [ Wed Aug 27, 2008 7:30 pm ] |
I'm pretty sure they used to make them, let's wait for John at Mini King to find this thread. It has to be straight cut? There are heaps of 998/1098 helical ones about... ![]() |
Author: | Hanra [ Wed Aug 27, 2008 7:39 pm ] |
Yes must be straight cut. I will be running a straight cut gear set in the future. The racket that Steve's race motor makes got me hooked.....! |
Author: | Monaco [ Thu Aug 28, 2008 10:47 pm ] |
I would try Somerford Mini in the UK, they were really helpful when I needed some hard to find bits that no one else seemed to be able to help with. I have straight cut drop gears in my motor, not so great for the road as the thrashing around (rattle) at idle can't be that great for them! ![]() BUT...They do sound good! ![]() Tip: I have the Jack Knight gears and they are much better quality than some of the others available. |
Author: | graham in aus [ Fri Aug 29, 2008 1:11 am ] |
Hanra, Try MED or Morespeed they build Mini Seven race motors, these still use 998 cranks and the smaller primary gear. Morespeed is an ex MED employee (Simon), he got my last two S/C small primaries, I swapped for 1275 ones! ![]() http://morspeed.co.uk/ http://www.med-engineering.co.uk/home.php ![]() |
Author: | Hanra [ Fri Aug 29, 2008 8:47 am ] |
Thank you for those links I will send off some emails!!! |
Author: | Hanra [ Fri Aug 29, 2008 7:13 pm ] |
Ive emailed MED, i cant find a bloody email address for morspeed at all... I found these on the Jack Knight site, looks promising!!! http://jackknight.co.uk/onlineshop/inde ... =1_180_146 |
Author: | Hanra [ Fri Aug 29, 2008 8:53 pm ] |
M.E.D's answer: Sorry we cannot help at this point in time as all of our S/C primary gears are made for the 1275 type crankshaft, we are having a fully floating bush made to convert the 1275 gear to be used on the 998 crankshaft but these will be 6 – 8 weeks away |
Author: | Morris 1100 [ Fri Aug 29, 2008 8:58 pm ] |
Be carefull with Jack Knight stuff. I think that Jack Knight went broke but the online shop is still up and taking money even though there is no one there to send the stuff out. (Sound like a good scam if you can get away with it! ![]() |
Author: | Hanra [ Fri Aug 29, 2008 9:27 pm ] |
Hahahaha.... True deal!!! Actually i do recall reading something about them going under. |
Author: | Hanra [ Sat Aug 30, 2008 7:04 am ] |
Jack Knights response: Our smallest bore is for the 850cc crank and the price for the dropkit is £350.00 plus £18.00 postage Thank you for your enquiry Nick |
Author: | feralsprint [ Sat Aug 30, 2008 5:17 pm ] |
May be what our looking for and it does say he will poist world wide in the description http://cgi.ebay.co.uk/Mini-Cooper-998-s ... dZViewItem |
Page 1 of 3 | All times are UTC + 10 hours |
