Disaster Averted. https://www.ausmini.com/forums/viewtopic.php?f=2&t=4530 |
Author: | djhaddo1 [ Thu Feb 03, 2005 8:48 pm ] |
Post subject: | Disaster Averted. |
I had the mechanics at work replace the rubber uni's on my Mini today. (luckily the mech boss used to have a mini when he was younger and thus is more than eager to volunteer his troops) They said the pax side literally fell apart as soon as they loosened the 3 remaining U bolts. One rubber piece was completely missing and the wear on the knuckles is somewhat concerning. Found one piece of the U bolts just sitting on the subframe. ![]() I'm just glad I had it done before going to Lithgow, would have been awful ugly otherwise.... Dan http://img.photobucket.com/albums/v517/djhaddo1/DVC01086.jpg http://img.photobucket.com/albums/v517/djhaddo1/DVC01087.jpg |
Author: | sg [ Thu Feb 03, 2005 8:52 pm ] |
Holy crap haddo.................. they are screwed ![]() ![]() |
Author: | djhaddo1 [ Thu Feb 03, 2005 8:56 pm ] |
Last time I got her serviced Ivan said they were on they way out. I didn't realise they would cark it so quickly. |
Author: | sg [ Thu Feb 03, 2005 9:00 pm ] |
That is some serious wear issues........... ![]() |
Author: | drmini in aust [ Thu Feb 03, 2005 9:01 pm ] |
djhaddo1 wrote: Last time I got her serviced Ivan said they were on they way out. I didn't realise they would cark it so quickly.
Oil leaks kill the rubber... ![]() You can get Nylon capped ones with needle rollers in them, they last much longer. p/no is QL5000 I think. Around $110/pr at Karcraft. ![]() |
Author: | J_A_M [ Thu Feb 03, 2005 9:39 pm ] |
![]() I haven't seen parts worn that bad, since my days at Qantas when we serviced an ex Pan Am plane!! |
Author: | 68matic [ Fri Feb 04, 2005 7:33 am ] |
dudes what was making that ubolt wear out so quickly? |
Author: | drmini in aust [ Fri Feb 04, 2005 8:07 am ] |
68matic wrote: dudes what was making that ubolt wear out so quickly?
The rubber collapsed and wore thru, then all there is are the U bolts and centre cross... ![]() Another thing to watch is the worn rubbers can rub on the gearbox casing and wear thru it! ![]() |
Author: | 68matic [ Fri Feb 04, 2005 8:18 am ] |
is there anything we should watch out for if we had steel uni joints? |
Author: | 1380 yellow devil [ Fri Feb 04, 2005 2:02 pm ] |
I have been told that if you do not keep a good check on them and let them go like the ones you had. They can wind up flying through the gear Box and making a mess. My Father has them on his 1310 for 5 or so years now and Never had a prob. I was told that bu my local Mini Man.?????? |
Author: | gafmo [ Fri Feb 04, 2005 4:46 pm ] |
1380 yellow devil wrote: I have been told that if you do not keep a good check on them and let them go like the ones you had. They can wind up flying through the gear Box and making a mess.
My Father has them on his 1310 for 5 or so years now and Never had a prob. I was told that bu my local Mini Man.?????? Oil and Grease on Rubber just does not Mix.... ![]() ![]() ![]() |
