It is currently Sun Aug 17, 2025 1:10 pm
 Post subject: Nice Head
PostPosted: Fri Aug 29, 2008 8:55 pm
Yes I know what it is but just a bit of a test for those out thier and its quiet on here
PostPosted: Fri Aug 29, 2008 8:58 pm
Give Ash some flowers Nick .
That's one nice looking head job :lol:
PostPosted: Fri Aug 29, 2008 9:17 pm
Give us a hint. I'm sure its not a KAD. Looks great, how much power will it make?
no not a KAD
PostPosted: Fri Aug 29, 2008 9:22 pm
Wot about BMW bike head?
PostPosted: Fri Aug 29, 2008 9:40 pm
rite make :wink:
PostPosted: Fri Aug 29, 2008 10:44 pm
John K (Specialised Components England) 16v K1100 BMW motorbike cyl head conversion
I have 30x of my own :-)
PostPosted: Fri Aug 29, 2008 11:04 pm
This space for rent
Joisus that's a big head. They put those on bikes??
PostPosted: Sat Aug 30, 2008 2:48 am
Would you call that a 'boof head' then Simon?
PostPosted: Sat Aug 30, 2008 7:50 am
is it an engine?
blokeinamoke wrote:
 Post subject: K.A.D. Head
PostPosted: Sat Aug 30, 2008 10:58 am
Oh while we are on the topic of heads, 2 of these puppies (KAD twin cam engine kits) came in this week....
Both have already been dyno'ed' at around 180bhp
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
www.minisport.com.au
Minisport for all your mini parts
PostPosted: Sat Aug 30, 2008 12:26 pm
oh my ! (wipes drool from keyboard) 8)
Im here to learn!
PostPosted: Sat Aug 30, 2008 12:34 pm
What is something like this worth? and do they need special radiators etc to keep em cool. Will they fit in a roundy without body mods ?
PostPosted: Sat Aug 30, 2008 3:37 pm
Around $40,000- That comes complete with bonnet, loom (for all injection, computer, full exhaust system, 5 speed dog box, straight cut drop gears, LSD, plus more
On the cooling an alloy radiator with a thermo fan should keep it cool.
It will fit (with supplied bonnet) in a roundy- but it will be tight the radiator shroud has to go, but that should be about it- i'll let you know once we have one fully installed.
This is from the KAD website:
170-180bhp, capacity 1380-1460cc.
KAD latest spec big valve 16 valve cylinder head with belt assembly,
A+ block with four bolt centre main cap, bored and honed
73.5mm flat top Cosworth or Omega forged pistons
Vandervell Competition engine bearings
EN40B billet steel crankshaft 81.28-86mm stroke
Forged steel Arrow conrods
HP oil pump, water pump
Aldon distributor with Ignitor Electronic ignition
KAD alloy flywheel and backplate
AP grey diaphragm pressure plate and clutch
4-2-1 exhaust manifold and 2" bore twin box system
Top and bottom radiator hoses, top radiator mounting
Complete engine unit built and dyno run
Engine as above with Omex Engine management, this includes complete
wiring loom and fuel system
Ph: 08-8177-1275
Skype: minisport.au
PostPosted: Sat Aug 30, 2008 4:46 pm
Hey Andrew, nice kit. My cooper is nearly on the road with the 5 speed I bought from you guys. I can' wait :D No way I could afford this monster tho :cry:
Users browsing this forum: No registered users and 72 guests
