| ausmini https://www.ausmini.com/forums/ |
| Grill panel stiffener Cooper https://www.ausmini.com/forums/viewtopic.php?f=2&t=45368 |
| Author: | crisonic [ Mon Sep 01, 2008 10:10 am ] |
| Post subject: | Grill panel stiffener Cooper |
Ah Pedantry at its best Does anybody know wether the diagonal grill stiffener fitted in MK1 Coper S australian production to clear the oil cooler ,was riveted or spot welded into the front body panel? I recall seeing both used but maybe the spot welds were on later production (MK2). Then again maybe I saw the panel beaters art at its best!!!! |
| Author: | 66S [ Mon Sep 01, 2008 10:59 am ] |
| Post subject: | |
To my knowledge, they were spotted with two spots, top and bottom. There seems to be a slight variation as to where they were spotted at the top, either as far rearward as they can go or forward about 1/4". Regards Al |
| Author: | doogie [ Mon Sep 01, 2008 12:35 pm ] |
| Post subject: | |
Both my 67 Mk1 & 69 MK2 are both spot welded in. Doogie |
| Author: | Mick [ Mon Sep 01, 2008 1:05 pm ] |
| Post subject: | |
My 69 is spot welded, but strangely there is a little pop rivet on the lower weld...it's not the usual kind of pop rivet, it's very small. I've seen it as well on a mini K I had around here at the same location, so it's not a one off.. picture on the way.. |
| Author: | jasonf [ Mon Sep 01, 2008 1:45 pm ] |
| Post subject: | |
My 67 Deluxe had the cooper style angled brace and is spot welded in 2 spots both top and bottom, must have been one of those "grab whats available" when put together |
| Author: | Kyoda [ Mon Sep 01, 2008 3:32 pm ] |
| Post subject: | |
Mick wrote: My 69 is spot welded, but strangely there is a little pop rivet on the lower weld...it's not the usual kind of pop rivet, it's very small.
I've seen it as well on a mini K I had around here at the same location, so it's not a one off.. picture on the way.. Our 69 S has the same. |
| Author: | doogie [ Mon Sep 01, 2008 3:33 pm ] |
| Post subject: | |
Kyoda wrote: Mick wrote: My 69 is spot welded, but strangely there is a little pop rivet on the lower weld...it's not the usual kind of pop rivet, it's very small. I've seen it as well on a mini K I had around here at the same location, so it's not a one off.. picture on the way.. Our 69 S has the same. You mean Wayne's 69 S is the same Doogie |
| Author: | Kyoda [ Mon Sep 01, 2008 4:00 pm ] |
| Post subject: | |
2 S's & a clubman wrote: Kyoda wrote: Our 69 S has the same. You mean Wayne's 69 S is the same Doogie No - I mean OUR 69 S. |
| Author: | doogie [ Mon Sep 01, 2008 4:01 pm ] |
| Post subject: | |
Kyoda wrote: 2 S's & a clubman wrote: Kyoda wrote: Our 69 S has the same. You mean Wayne's 69 S is the same Doogie No - I mean OUR 69 S. Doogie |
| Author: | Morris 1100 [ Mon Sep 01, 2008 4:34 pm ] |
| Post subject: | |
My 68 Cooper S has pop rivets top and bottom.
But I guess that may have happened after a race crash in the late 60s. It has had a hard life and copped a big hit in the right front at some stage. I doubt if any panel beaters had spot welders back then. (I doubt if many had Migs back then! |
| Author: | John Smidt [ Mon Sep 01, 2008 5:23 pm ] |
| Post subject: | |
Both pop riveted and welded are correct In My Opinion, Over the years I have noticed both, Around 1969 they were welded more often than pop riveted, This is from my experience only, I am not saying this is Gospel |
| Author: | Mick [ Mon Sep 01, 2008 5:41 pm ] |
| Post subject: | |
Here's the pic I promised. Spot welded and the lazy rivet in the bottom. Sorry for the quality the camera is on the blink so can't take a new photo of the blasted brace... It's a bit vague but the factory rivet is just to be seen in the bottom weld in the center.
| Author: | crisonic [ Mon Sep 01, 2008 9:15 pm ] |
| Post subject: | |
Thanks to all for the response . Seems like there is no definitive answer. It all started when I looked at my BMC published parts bookHYL3698 Oil cooler page AC12 and it shows rivets Part No DXR408 QTY4 This is an early Cooper S parts page ( around 1966). So rivets were certainly there for some part of the production life |
| Page 1 of 1 | All times are UTC + 10 hours |
| Powered by phpBB® Forum Software © phpBB Group http://www.phpbb.com/ |
