It is currently Sun Jul 27, 2025 8:31 pm
 Post subject: 12YD
PostPosted: Tue Apr 08, 2008 7:37 pm
Just got a quick question as im a little baffled. Is the 12YD motor a 1275cc found on late model clubmans or is it a 1100s motor found on the rovers as i have found conflicting advice both on this site when i did a search and also on the net and all this confusion is making my head hurt :shock: :shock:
 Post subject: Re: 12YD
PostPosted: Tue Apr 08, 2008 7:41 pm
12YD/Ta/H is a later Morris 1100S, 1275cc.
The changeover for cranks small journal/ large journal is 12YD/Ta/H10487 - 12YD/Ta/H10488
Earlier small J ones were 12Y/Ta/H prefix.
I have a few examples.... :wink:
Last edited by drmini in aust on Tue Apr 08, 2008 7:46 pm, edited 1 time in total.
PostPosted: Tue Apr 08, 2008 7:45 pm
Cheers Doc
Then which ones were on the 1275LS clubby's, were they the 12H motors?
PostPosted: Tue Apr 08, 2008 7:47 pm
Not seen one lately but yes I believe so.
They were UK built motors, basically same as a UK 1275GT.
PostPosted: Tue Apr 08, 2008 7:53 pm
A lot of the engine number guides on the net are wrong about the Australain engine numbers.
The 1275LS got an engine with 12H902UH******, they never got 12YD/Ta/H. It was impossible! But a lot of websites will tell you differently.
The 1275LS motor is similar to an Austin Allegro but with a pollution air pump.
PostPosted: Tue Apr 08, 2008 8:05 pm
So I'm learning. :evil:
Thanks for all your help guys
PostPosted: Tue Apr 08, 2008 8:20 pm
Were the LS engines mechanically fuel pumped or otherwise??
I have a plate on the pump hole, and a PO fitted a facet down aft.
PostPosted: Tue Apr 08, 2008 8:27 pm
LS all had a mech pump. :wink:
PostPosted: Tue Apr 08, 2008 8:33 pm
Yep. :D
PostPosted: Thu Jul 24, 2008 10:38 am
So the 12YD engine is the morris 1100s one?
My mini K has one fitted in it,, and its been hurting my head too!
PostPosted: Thu Jul 24, 2008 10:42 am
Give Ash some flowers Nick .
WHOLLY THREAD REANIMATION BATMAN! :P
Better this way than starting a new thread though IMHO.
Used in Morris 1100S and probably early 1275 Moke
:wink:
PostPosted: Thu Jul 24, 2008 10:50 am
:wink:
Search button is there for a reason... :wink:
PostPosted: Thu Jul 24, 2008 10:58 am
BEST.......
QUOTE......
EVER!
:mrgreen:
PostPosted: Thu Jul 24, 2008 11:58 am
Son's Moke has a 12YD/Ta/H motor - but it's a transplant - other numbers don't match and it has drum brakes :?
David L
PostPosted: Thu Jul 24, 2008 4:47 pm
A Moke will not have been made with a 12YD/Ta/H motor.
It is a Morris 1100S motor and nothing else. :wink:
The D refers to a variant only used in the 1100S
The Ta refers to the remote control centre change gearbox that was not fitted to the Moke (they have a U instead of a Ta)
