It is currently Sat Jul 26, 2025 11:32 am
PostPosted: Sun Aug 31, 2008 8:56 pm
After putting on the new wheels with black centres i thought a whit roof didint suit, so i thought i'd change it to black.
But first i'd try a black and dark grey checker for something different.
First step is to clean the roof
2/ Fit the vinyl on the roof and cut off corner excess
3/ Wet the roof and flip the vinyl face down so the paper side is facing up and careful peel the paper backing off
4/ Wet the vinyl with a drop of detergent in a water spray bottle
5/ Flip over the vinyl and position it on the roof
6/ Use a squeegee to get the water out from under the vinyl
Start by going from the centre to the back of the car, then the centre to the front of the car, then work your way back to the sides leaving the corners to last
7/ Now for the tricky part, using a heat gun heat the edge of the vinyl to soften it up, then use your small squeegee to push the fluid and the wrinkles out to the edge.
Nice and slow is the way to go with this moving from the centre of the corners out towards the sides
8/ After working the edges to the gutter, heat and push in the edges up to the edge of the outside gutter. Once happy trim it back with a sharp scalpel.
If you need to clean up the edge on the gutter, wrap a 15-20mm pinstripe aroung the outside of the gutter and cover the edge you have just cut.
Alternatively if your roof is the same colour as the body work you can trim the vinyl to the roof edge.
Then stand back and admire your work...
PostPosted: Sun Aug 31, 2008 9:01 pm
Looks great Shane, well done.
Matt
PostPosted: Sun Aug 31, 2008 9:06 pm
looks awesome.. good work
PostPosted: Sun Aug 31, 2008 9:09 pm
I want to see the "Paul Smith" version of Alice! Top job Chop :wink:
PostPosted: Sun Aug 31, 2008 9:21 pm
Resident Haemorrhoid
:shock: 8) 8) 8)
how bout a carbon fibre print to make ricers jealous :wink:
teh power to weight ratio would be better :roll: :lol: :lol:
mtsmini wrote:
Tombo wrote:
PostPosted: Sun Aug 31, 2008 9:26 pm
How about this one Chop?
Are you up for it? :mrgreen:
PostPosted: Sun Aug 31, 2008 9:38 pm
High heel ninja
That looks 5hit hot Shane, we'll done.
Doogie
PostPosted: Sun Aug 31, 2008 9:40 pm
we can cover it up, will look new 1100
PostPosted: Sun Aug 31, 2008 9:56 pm
No way would I try it but You can do it for me...Look Great and something Differant 8)
PostPosted: Sun Aug 31, 2008 10:44 pm
WOW!! that looks sen-frigging-sational
I wondered if a roof could be covered like that..... I'm tempted to try a black roof on my cooper
PostPosted: Sun Aug 31, 2008 11:15 pm
Awesome Shane, you've done it again! :P
As if you aren't busy enough, now think of all those roofs you'll be doing!
Sir Alec! we are not worthy!
PostPosted: Sun Aug 31, 2008 11:25 pm
Milatsmadmini
roof looks f*ckin A choppers! well done mate.... perhaps another batch could be made and sold off? just hinting that one.... :wink:
PostPosted: Sun Aug 31, 2008 11:53 pm
Looks great Chop 8)
gotta keep it like that, at least for a while
PostPosted: Mon Sep 01, 2008 12:00 am
chop that is very cool mate
PostPosted: Mon Sep 01, 2008 1:59 am
I thought this was going to be a very ordinary idea until I saw the pictures - I like!
Where do you get the vinyl and what colours/patterns can you get?
Noli Illegitimi Carborundum
